Robert Welford Posted July 17, 2019 Share Posted July 17, 2019 Peter, I've sent you a message. Robert Quote Link to comment Share on other sites More sharing options...
Max Z Posted July 17, 2019 Share Posted July 17, 2019 Posted by Percy Verance on 17/07/2019 19:13:39: and the vulnerable exposed aerial. I've never broken one yet, but I know those who have. I have to agree to that. On the older one, to get a better protectionI modified the mounting to swing it back (and fix it) in the same way the 35MHz antenna could . Nothing wrong with the NiMh battery as far as I am concerned, must be nearly a year ago I last had to charge it. Quote Link to comment Share on other sites More sharing options...
Former Member Posted July 18, 2019 Share Posted July 18, 2019 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Paul Bromley Posted August 13, 2019 Author Share Posted August 13, 2019 Hopefully guys on here can answer another question ? sorry ! I have set up conditions, I only need two and used the dual rate switch to switch between conditions 1 and 2. I was then able to use different amounts of expo with mild and wild movements. However I find I need different servo end points as well, again my lack of understanding isn't letting me grasp this, can anyone tell me how this can be done ? Many thanks. Paul. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted August 13, 2019 Share Posted August 13, 2019 Paul, you can set rates per flight condition (phase) too, this then adjusts the servo throw. Quote Link to comment Share on other sites More sharing options...
Paul Bromley Posted August 13, 2019 Author Share Posted August 13, 2019 Thanks Frank, I am doing this, the problem is I have two elevator servos on separate channels where the movements on low rates need to be about 12 degrees and oh high rates about 60 degrees, so they have very large servo arms. The problem is the two down elevator movements don't quite match in the low rate, so I was hoping there was a way to adjust servo end points in both flight conditions to exactly match servo movements. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted August 13, 2019 Share Posted August 13, 2019 Paul that also means when you move the elevator stick in high rates to give 12 deg then they will be out too, you need to get the servos matching. It suggests that there is some slight mechanical difference in each elevator linkage. The best way is to adjust the mechanical linkage so they both move the same, but you can use the servo curves (5 point on the Cockpit Sx and Royal Sx and 9 point on the Profi), so the elevator halves move in unison. The MPX way is always to adjust the servo curves first to get equal response to the input and then adjust the required control inputs per flight phase/dual rate. Quote Link to comment Share on other sites More sharing options...
Paul Bromley Posted August 13, 2019 Author Share Posted August 13, 2019 Thanks Frank, I will give that a go, I think the difference is probably one spline, but if I move one arm its out the other way if you follow ! Best wishes paul. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted August 13, 2019 Share Posted August 13, 2019 Just adjust one of the servos mid point in the servo curves so the arms are aligned and then the mechanical linkage so both elevator halves are level, then by adjusting the end points they should move together in unison to the control input. Quote Link to comment Share on other sites More sharing options...
Paul Bromley Posted August 14, 2019 Author Share Posted August 14, 2019 Todays project in the pouring rain ... thanks very much. Frank. Paul. Quote Link to comment Share on other sites More sharing options...
