Toni Reynaud Posted January 24, 2020 Share Posted January 24, 2020 Nice job with the cylinder mounting. You may wish to consider lining the inside with light fibreglass to reinforce the plastic moulding. I recall that that was the bit that tore/split with the vibration. Quote Link to comment Share on other sites More sharing options...
Robert Parker Posted January 25, 2020 Author Share Posted January 25, 2020 Hi Chris, Yes, the OS does bend in nicely. I chose to use a four stroke for exactly that, the prototype used a .29 two stroke and did not fancy the large silencer sticking out the side. I have been dropping in now and again with your sabre build and as always you build so neatly and your bench is tidy unlike mine. Alan, thank you, It came out better than I had expected. Toni, this did cross my mind but having had to rasp away some of the engine bearers to get the cowl to fit I'm going to give it a miss, might regret it later but I don't fancy the bearers failing either. I could always make a large cowl and it would look like a "K" version. Regards Robert Quote Link to comment Share on other sites More sharing options...
Robert Parker Posted January 26, 2020 Author Share Posted January 26, 2020 Hi All, The Avro is now all but completed just waiting on a pilot and to sort the rigging wires (elastic thread). All of the servos are now fitted, I left this until I balanced the model so I could move the servos but in the end I did not have to move them at all just changed the LiFe battery for Nimh battery (6v) for a nice nose down attitude. Closed loop for the rudder fitted along with the snake inner for the elevators and bit of fiddling and slight cursing for the throttle servo and the aileron servos fitted. Control throws adjusted to best guess on three rates, I have looked through the instructions and over the plans and there seems no mention of any throws for the rudder and elevator. As for the ailerons I have added more up than down and again set up three rates. All up weight came out just over 6lbs or 2.7kg which is 1/2lb heavier than the review model back in 1978 most of the weight I guess would be from the iron-on covering instead of light weight tissue and the 40 4st motor instead of the .29 2st motor. With a total wing area of 896 sq ins or 0.57sqm gives a wing loading of 15.01 oz/sqft with a stall speed of 19mph so a nice gentle flyer I hope Just need to wait for the pilot, some decent weather for a photo shoot and the flying field to dry out a bit for the maiden. That's all for now Regards Robert Quote Link to comment Share on other sites More sharing options...
Robert Parker Posted February 1, 2020 Author Share Posted February 1, 2020 Hi All, Finished, all except the pilot and maiden flight. Rigging was a bit of a pain to do and the interplane struts need some sort of retaining method. I was hoping that the rigging would hold them in place but no. I managed to do some photos in the garden this afternoon. I thought the rigging wires were a bit thick but they are about right Position wanted Just need a suitable pilot and some weather and maiden her. What to build next.................... That's all for now, I'll keep you all posted when the maiden happens. Regads Robert Quote Link to comment Share on other sites More sharing options...
Jimbo565 Posted February 1, 2020 Share Posted February 1, 2020 Cracker job Robert, well done Quote Link to comment Share on other sites More sharing options...
J D 8 Posted February 1, 2020 Share Posted February 1, 2020 Like it, good luck with maiden. Quote Link to comment Share on other sites More sharing options...
David Davis Posted February 1, 2020 Share Posted February 1, 2020 Superb job Robert. Best of luck with the maiden. Quote Link to comment Share on other sites More sharing options...
Broken Prop Posted February 1, 2020 Share Posted February 1, 2020 Lovely! A beautiful build that deserves to fly well. Good luck Robert! Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted February 1, 2020 Share Posted February 1, 2020 Great looking model Robert, you must be very pleased with it. Looking forward to some in-flight photos. There is the Veron plan available on Outerzone for those who are now inspired to build one! Quote Link to comment Share on other sites More sharing options...
Toni Reynaud Posted February 2, 2020 Share Posted February 2, 2020 That looks lovely. It should fly well. Quote Link to comment Share on other sites More sharing options...
Alan H Posted February 2, 2020 Share Posted February 2, 2020 Very nice job, looking forward to your reports on the maiden. I'm sure it will fly well Quote Link to comment Share on other sites More sharing options...
