Roger Dyke Posted October 15, 2019 Share Posted October 15, 2019 Hi All, Recently, I encountered two large dings in the leading edge of my aircraft's wing each side of the fuselage about half way between the fuselage and the wing tip. The wing is foam with 4" of balsa sheeting on the front edge (top & bottom) where it is glued to the leading edge. The dings pushed the leading edge back about a inch or so and crushed the foam and balsa sheet. The dings are about 3-4" wide. I am making up a new piece of leading edge for each, but before I repair the sheeting I need to fill the hole left by the expired foam. What is the best way of doing this? I do have a large block of foam at my disposal so I was thinking to shred some of this into the hole probably mixed with a little PVA glue. What do you reckon? Your thoughts would be very much appreciated. Roger Quote Link to comment Share on other sites More sharing options...
Don Fry Posted October 15, 2019 Share Posted October 15, 2019 One way forward is use gorilla (expandeded polyurethane) glue. Wet the foam. Put some gorilla on the wet foam, put masking tape on the wing, to follow the final outline, and the foaming glue tends to fill the hole. And repeat if you were parsimonious. Final fill with micro light filler. Quote Link to comment Share on other sites More sharing options...
Don Fry Posted October 15, 2019 Share Posted October 15, 2019 You could also shred some foam, and mix it with Gorilla glue. Keep it light. Weight is the enemy of repaired aircraft. Quote Link to comment Share on other sites More sharing options...
Roger Dyke Posted October 15, 2019 Author Share Posted October 15, 2019 Thanks for that. Do they have that sort of Gorilla glue in the local DIY? Quote Link to comment Share on other sites More sharing options...
conrad taggart Posted October 15, 2019 Share Posted October 15, 2019 B&Q sell it - the clear one is the best - most versatile in terms of matching / not showing. They also do a brownish one Quote Link to comment Share on other sites More sharing options...
john davidson 1 Posted October 15, 2019 Share Posted October 15, 2019 the clear gorilla glue does not foam up to expand into spaces like the brown one, both excellent glues Quote Link to comment Share on other sites More sharing options...
Roger Dyke Posted October 15, 2019 Author Share Posted October 15, 2019 Thanks for the replies and the info. Quote Link to comment Share on other sites More sharing options...
Old Geezer Posted October 15, 2019 Share Posted October 15, 2019 The way I've repaired similar damage in the past is: cut out the entire damaged section using a razor saw, a nice fresh and very sharp #22 blade and a straight edge, cut a piece of soft balsa ( grain running laterally, obviously ) to exactly fit your now tidy hole in the leading edge. My own preference is to cut out the damage obliquely at each end and the ends of the balsa replacing the deficit at a similar angle - thus ensuring a snug fit without lots of trimming, logical when you think about it. Now all you have to do when the white glue is dry is plane and sand the balsa to section and re-cover. The balsa was usually found in those cheap packs of off cuts at your LMS - used to be too cheap not to always have a pack or two in the shed, kept in the 'might come in useful' box. Quote Link to comment Share on other sites More sharing options...
DDH Posted October 16, 2019 Share Posted October 16, 2019 Helpful info here re repairs to foamies: https://www.modelflying.co.uk/forums/postings.asp?th=126936 http://www.crashtesthobby.com/how-to-repair-a-damaged-plane.html https://www.modelairplanenews.com/easy-foam-repair-tips/ Quote Link to comment Share on other sites More sharing options...
DDH Posted October 16, 2019 Share Posted October 16, 2019 I'm told by those who know about these things that 'Copydex' adhesive is superior to PVA: **LINK** Edited By - on 16/10/2019 07:04:22 Quote Link to comment Share on other sites More sharing options...
Roger Dyke Posted October 16, 2019 Author Share Posted October 16, 2019 Old Geezer: I never really thought of filling it with soft balsa. That's a good idea, thanks for that. - : Thanks for the links, I'll have a look at them. Quote Link to comment Share on other sites More sharing options...
Old Geezer Posted October 16, 2019 Share Posted October 16, 2019 Roger - my first skinned foam wing repair was a build-it-yourself Fuji40 powered Wot4 that I had flown into a Leylandii at full chat on one of my rare off duty Sunday afternoons - the wing was repaired, solartexed, fuel proofed and ready to go by the middle of the week, as usual, the limiting factor was the drying time of the aliphatic glue and curing time of the fuel proofer. By the by - varnished or fuel proofed Antique Solartex looks really nice on one of C.F.'s b.i.y. Wotties, it shows up the grain of the balsa and adds some strength to the airframe - ok, not as much as glassing, but so so much less of a faff. Quote Link to comment Share on other sites More sharing options...
Roger Dyke Posted October 16, 2019 Author Share Posted October 16, 2019 Old Geezer: That sounds very encouraging. Thanks for that. Quote Link to comment Share on other sites More sharing options...
Stuart Z Posted October 16, 2019 Share Posted October 16, 2019 Depending on size of “hole” I’ve used Polyfilla Advanced, pick up a tub and you’ll see it is very light. S Quote Link to comment Share on other sites More sharing options...
Roger Dyke Posted October 16, 2019 Author Share Posted October 16, 2019 Hi Stuart, I haven't seen that one. I'll have a look at it. Thanks. Roger Quote Link to comment Share on other sites More sharing options...
Rich too Posted October 16, 2019 Share Posted October 16, 2019 Posted by Old Geezer on 15/10/2019 23:51:33: The way I've repaired similar damage in the past is: cut out the entire damaged section using a razor saw, a nice fresh and very sharp #22 blade and a straight edge, cut a piece of soft balsa ( grain running laterally, obviously ) to exactly fit your now tidy hole in the leading edge. My own preference is to cut out the damage obliquely at each end and the ends of the balsa replacing the deficit at a similar angle - thus ensuring a snug fit without lots of trimming, logical when you think about it. Now all you have to do when the white glue is dry is plane and sand the balsa to section and re-cover. The balsa was usually found in those cheap packs of off cuts at your LMS - used to be too cheap not to always have a pack or two in the shed, kept in the 'might come in useful' box. You could use soft balsa block, or make a few “ribs” to fill the hole and give the sheet some support. Quote Link to comment Share on other sites More sharing options...
Roger Dyke Posted October 16, 2019 Author Share Posted October 16, 2019 Yes, that's true. I now have more than enough ideas from your good selves to have a look at. My thanks to you all for you very valued replies. Roger Quote Link to comment Share on other sites More sharing options...
