Christopher Morris 2 Posted April 11, 2020 Share Posted April 11, 2020 I have an electric Boomerang plane nearly ready to go, but have a small problem with when i turn the rudder the ailerons are also getting a tiny signal & move just a fraction of an inch. So small that it wouldn't make any difference. I am assuming its something in the DX6e settings that i am using. Any suggestions on which menu i should have a look at?? Thanks & hope your all well. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted April 11, 2020 Share Posted April 11, 2020 This is a common MIX on certain models Chris, but is more usual the aileron moves the rudder Look at the menu under Monitor, and see that those servos are moving at the same time due to the transmitter stick Then go into MIX And look there for RUD > AIL Coupled, and INH the MIX of zero the two Edited By Denis Watkins on 11/04/2020 15:25:55 Quote Link to comment Share on other sites More sharing options...
cymaz Posted April 11, 2020 Share Posted April 11, 2020 Page32 should see you right Quote Link to comment Share on other sites More sharing options...
Peter Jenkins Posted April 11, 2020 Share Posted April 11, 2020 Always best to reset a memory before setting up a new model just in case there are some odd mixes or set ups in there. Quote Link to comment Share on other sites More sharing options...
Christopher Morris 2 Posted April 12, 2020 Author Share Posted April 12, 2020 Thanks everyone. Did a cleanup on everything & found the rudder was set to one & Ailerons set to -1 & found servo>travel>sub trim & set these 2 items to 0 seem to solve it.. Seems to have worked. Thanks Quote Link to comment Share on other sites More sharing options...
