David Ramsden Posted June 16, 2020 Share Posted June 16, 2020 Just putting together my first electric flight set up. I managed the shaft reversal on a Rimfire 400 without too much trouble and used Loctite 648 where thread locking was indicated. Now thinking about the JP ali spinner and folding prop. Should I use loctite on the spinner nut & screw and on the blade-retaining screws? I guess there's less vibration with electric motors than there is with IC. Do things work loose over time? Should I Loctite everything? Thanks, David Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted June 16, 2020 Share Posted June 16, 2020 David, no, thread lock is not required on those. Quote Link to comment Share on other sites More sharing options...
Ronaldo Posted June 16, 2020 Share Posted June 16, 2020 All my folding props come with nyloc nuts on the blade retaining bolts. You don't need threadloc on those. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted June 16, 2020 Share Posted June 16, 2020 Just remember to balance your props to reduce, if not eliminate, vibration. Also there are products that are just retainers and not full bond, if you follow me. Some are colour coded, red , green etc. D.D. Quote Link to comment Share on other sites More sharing options...
Former Member Posted June 16, 2020 Share Posted June 16, 2020 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
