What to do with an old camera tripod
Tim C
Great idea Tim!
If you can strap the model on to the stand, you have the added advantage of using the lockable tilt to hold the model in other attitudes should you need to work on the undercarriage, for instance.
You may want to stake the feet of the tripod into the ground if you are planning to run up the motor whilst on the stand.
Robin
