Tim C Posted July 14, 2020 Share Posted July 14, 2020 2 bits of old waste pipe, some 20mm insulation foam and a piece of scrap plywood, screw to the tripod quick release and instant lightweight height adjustable field stand Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted July 14, 2020 Share Posted July 14, 2020 Like it. Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted July 15, 2020 Share Posted July 15, 2020 Quote Link to comment Share on other sites More sharing options...
Robin Colbourne Posted July 15, 2020 Share Posted July 15, 2020 Great idea Tim! If you can strap the model on to the stand, you have the added advantage of using the lockable tilt to hold the model in other attitudes should you need to work on the undercarriage, for instance. You may want to stake the feet of the tripod into the ground if you are planning to run up the motor whilst on the stand. Robin Quote Link to comment Share on other sites More sharing options...
Tim C Posted July 15, 2020 Author Share Posted July 15, 2020 Stage 2 was to add some Velcro straps, comes with built in level, maybe useful if your setting up a gyro, and a hook to weight it if you want more stability Quote Link to comment Share on other sites More sharing options...
