Basil Posted July 22, 2020 Share Posted July 22, 2020 I am looking at the possiblity of using a lightwieght,white (Logic F-RCA117 Plastic control rod ) plastic control rods for elevators. It is obvious that they will need support!!!!. What guidance would builders give about their use and limits please. Bearing in mind that I am a mature returnee !!!! I am also puzzled as to how and with what you would couple up the cable to aflying surface and servos. Thank you in advance Barry Edited By Basil on 22/07/2020 12:21:00 Edited By Basil on 22/07/2020 12:48:05 Quote Link to comment Share on other sites More sharing options...
Bruce Collinson Posted July 22, 2020 Share Posted July 22, 2020 Basil, Will depend heavily on the unsupported length and the elevator load. I've gone off these, although they are handy for awkward narrow fuselages. Maybe dry mount it and see how floppy it is? End fittings usually involve a clevis, aka quicklink. The snakes I've used, SLEC and Sullivan, have hollow inner cables to thread studding, M2 probably, giving lots of adjustment. BTC Quote Link to comment Share on other sites More sharing options...
Nigel R Posted July 22, 2020 Share Posted July 22, 2020 Limits, something very lightweight... or very slow. Also, these things are rather prone to expansion and contraction with temperature change. For coupling to a control, use a threaded metal M2 extender and crimp it. You can buy them with a snaplink ready bonded to one end, leaving just the single crimp to sort out. **LINK** Quote Link to comment Share on other sites More sharing options...
