XHT module
WayneB
Not quite the answer you want but I have fitted the previous (DHT) module into a Futaba Conquest Tx and works fine. Quite easy to do with a little care on the connections but sorting out the aerial fitting etc was the hardest part.
The new XHT module would appear to be LBT/EU legal and mates with a wider range of receivers than the DHT..
I did a couple of Sanwa RD6000 Supers a number of years ago using the original hack module.
RD6000 Conversion.
I then converted a DX7 early one using the newer DHT module. This is still in use and is mainly used as my buddy box.
The only drawback as far as I can see is, no OpenTX.
They are great bits of kit and can breath new life into an old favourite TX.
Kev
