Frank Skilbeck Posted May 4, 2021 Share Posted May 4, 2021 Just test flown a new model using a Beatles 40A BEC ESC, motor is pulling 33A max on a 3s Lipo so no problems there. ESC BEC is driving a Multiplex Wingstabi Rx with 4 x 12/15 gram servos, in flight I was getting a low receiver voltage warning with the a volts readout of 4.7 to 4.8v (alarm was set at 5v), should I be worried or just set the alarm a but lower? Quote Link to comment Share on other sites More sharing options...
Dickw Posted May 4, 2021 Share Posted May 4, 2021 I have found that gyro equipped receivers tend to work the servos harder and it does only seem to be a 3A BEC. A volt drop of up to .3v on a regulated supply does suggest it is being pushed harder than it likes - unless there is an obvious cable/connector issue. I think I would be a bit nervous! Dick Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted May 4, 2021 Author Share Posted May 4, 2021 I have another 60A Esc with a 5.5v 5A UBEC, I'll put that in for peace of mind. I have used a Wingstabi on a larger aerobatic aircraft (Digital servos) with a similar ESC and didn't get any warnings. Will the try the 40A with a regular Rx and see how it performs on that. Quote Link to comment Share on other sites More sharing options...
