Mike Downs Posted March 26, 2010 Share Posted March 26, 2010 I have replaced the batteries to Flight tech 3800-11.1v lipos and have done the readings again..... Battery A Amps Watts Volts No load 12.6 30 313 10.6 1st run 30 320 10.6 2nd run Battery B No load 12.5 30 318 10.7 1st rum 30 320 10.6 2nd run Given the speed controllers and the motors does this look OK to go? Thanks Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted March 26, 2010 Author Share Posted March 26, 2010 Thats much more like it... the battery is now holding the sort of voltage I would expect and the other figures correspond also. Quote Link to comment Share on other sites More sharing options...
Mike Downs Posted March 26, 2010 Share Posted March 26, 2010 Thanks for that....... one more question.....as the amps are 30; does that mean because the juice is going through 2 speed controllers (which are 30 amp controllers) is shared i.e. 15 amps trhrough each,or both taking 30 amps each? Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted March 26, 2010 Author Share Posted March 26, 2010 Yes, shared between the two motors and ESCs. Quote Link to comment Share on other sites More sharing options...
John Sheehy Posted April 30, 2010 Share Posted April 30, 2010 Just a crazy thought, the motors arn't connected in series by any chance. Disconnect one motor and see if the other one works.John. Quote Link to comment Share on other sites More sharing options...
Josip Vrandecic -Mes Posted December 24, 2011 Share Posted December 24, 2011 Dear Tim,first of all,I'm new leccy as you already know ,so I just started with "operations"on conversion ic trainer to electric one.It was Tiger trainer 0.46 and now has a motor BC 3542/6 1000kv ,according to your recommendation .The model weight is 1700 g add equipment 440 g ,the result is 2140 g. Best wishes from your student.... JoEdited By Josip Vrandecic -Mes on 24/12/2011 11:21:28 Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted December 24, 2011 Share Posted December 24, 2011 Jo Rather than modify an IC engine mount had you considers fixing the motor directly to the bulkhead like in the photo below, makes it very easy to adjust the standoff and also thrust line. Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted December 24, 2011 Share Posted December 24, 2011 Jo if you would like an electric conversion kit ,I have a spare from the Sparrowhawk and could send it to you,would you like it gift wrapped Quote Link to comment Share on other sites More sharing options...
Josip Vrandecic -Mes Posted December 24, 2011 Share Posted December 24, 2011 Thanks Frank,but due the reason of of CG psn ,I used old long mount,otherwise the crews that were too long ,I don't have such ...in my area has no local shop... Merry Christmas . Jo. Edited By Josip Vrandecic -Mes on 24/12/2011 12:03:53 Quote Link to comment Share on other sites More sharing options...
Josip Vrandecic -Mes Posted December 24, 2011 Share Posted December 24, 2011 Dear Stephen ,no thanks ....this struggle for the equipment is really strong challenging.. By the way...have a good time ....I hope she is there.... Cheers Jo. p.s. I wont to tell everyone that you are very kind and nice person ... Edited By Josip Vrandecic -Mes on 24/12/2011 11:50:12 Edited By Josip Vrandecic -Mes on 24/12/2011 11:51:56Edited By Josip Vrandecic -Mes on 24/12/2011 12:10:58 Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted December 24, 2011 Author Share Posted December 24, 2011 I would agree with Frank on the mounting....but hey if it works for you thats good Best of luck with it all Jo... please let us know how it all goes after you have flown it.Best wishes...Tim. Quote Link to comment Share on other sites More sharing options...
Josip Vrandecic -Mes Posted December 24, 2011 Share Posted December 24, 2011 Frank and Tim,I absolutely agree with Frank solution,but it involves waiting for a month(Hobby King) ,I want to fly ASAP,so, take into consideration ,because I'm not stubborn person...lol. Between two options present now,I chose the right side..... Thanks for your time. Cheers Jo. Quote Link to comment Share on other sites More sharing options...
