Looking for 16 ohms
I use a car bulb normally to discharge nicads . I now am looking for a 16 ohm "something or other" to discharge my 1345 mAh 2s Rx lipo at 1C if my calculations are correct .Can anyone think of any normal bit or bob of a house hold nature think of a lightly candidate fit for the purpose .I've tried several bulbs but nothing seems to come close (unless of course I start wiring them up in series/parallel -A lot of bother & cumbersome !)  All suggestions welcome to save a days travelling to buy a resistor !
Phil   !  You are so right  Thank you .Dont know what happened to my brain cell ? I agree it is of course 5.5 ohms for 7.4 V & 6.1 ohms for the 8.24 V its at at the moment  I got a bit mixed up trying to work out what 12V rated bulb I could use -Somehow or other I got  waylayed by the wrong facts (even 'er indoors agreed it was 16 ohms - then again shes only a Phd Doctor etc      Thanks to you Bruce for your efforts  & no we dont have any wire that long in the shed but I found some rope -( No suggestions please .)Will now try & find a 6 ohm bulb (tried 'er indoors's iron but got weird meter readings(no use ---the iron that is !) Probably got a chip in there similar to the one on my shoulder . Gone are the days of a simple rheostat or so it seems --Same goes for my solarfilm iron .Well I have at least broadened my knowledge  I think ---until the next problem -tomorrow
make sure you check resister values when you get them at maplins - I bought 2 recently along with other stuff and didn't bother to check  until I went to use them and they were both wrong values.  I had assumed they knew there stuff.
Ah but that would apply if the person concerned was going to stick with elektrickery
Incidentally Myron do not worry about the discharge rate being exactly 1C - that was only a suggestion, and anything up to around 3 or 4 A with no worries. Discharfging them at even lower rates would also be OK....but might take a long timne ! The only really important thing in this project of yours is to ensure that
A) The discharge rate is not higher than the cells are rated at
B) The voltage at which you MUST stop the discharge is 6V ( when off load ) If you end up discharging at say 3A then you would need a resistor of around 2 to 3 Ohm ( at least 25 Watts )  and at this sort of current the battery can drop to around 2.85V per cell .....so around 5.7V.
When you get this low ( as monitored by a simple DVM across the pack during the process ) disconnect the load, and then check the off load voltage...it should read around 6V or so fairly quickly. It is important to "drain" this pack quite deeply, in order that you can accurately measure how much goes back in when you re-charge. Dont expect full capacity in this "born again" pack, but a few cycles and she may be back to a very useable level. Cant remeber if you had a balancer, but if not, then best to hook a seperate DVM across each cell as it is discgharging to ensure one cell hasnt suffered more than the other....ditto on the recharge.
Thanks Timbo   Am at this very moment discharging it with 5 servos connected to the regulator/Rx til I find a 6 ohm resistor (not 16 as I miscalculated!)  .Only a small discharge rate I know and am checking battery voltage & voltage going to the Rx every half hour .After 3 1/2  hours so far the battery has dropped from 8.22V to 7.80V  & the voltage to the rx has been 5.0 V until half an hour ago when it dropped to 4.99V  So far so good & will repeat procedure when battery drops to about 7.00 V ( is that -"deep enough" ? ) Yes I do have a balance charger & Black to no1 red is3.98 V  & Back to no 2 red is 7.82V  .Not too much imbalance I would assume ? Fingers crossed.Could be a long night for 'er indoors
Andy ---- I havn't given up yet --Only when my wallet says to me ----Go & buy some proper fuel while you can  & tin hats are for H&S devotees only
 & by the way I'll swap about 7 chargers for one discharging device !!
Will do -now - having re charged last night after falling to 7V - one cell taking 8 mins longer than another to charge - .but a slight increase up to 8.29V (90 % charge ).Wondering whether the 6 servos I have connected will speed up the discharge fractionally ?. Sorry to ramble on about this little problem but the experience may well help others who make "novices" mistakes
