flight1 Posted March 23, 2022 Share Posted March 23, 2022 Hi does any body know or have a tappet screw for a asp 160twin (same as for 79/80FS) part no 80724 also the rocker cover (part no 80711). someone must have them laying around/stashed away. Just engines says out of stock. Will pay for them Any ideas? Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted March 23, 2022 Share Posted March 23, 2022 Asp have been obsolete for some time now. The tappet screw can easily be made from a small cap screw and appropriate nut. Not sure about the cover though . Might be the same as the 80 fs. Try giving Weston UK a ring and talk to Alan. They were distributors of Magnum engines some years ago , same as ASP,SC. They may still have some bits laying around . You could run it without the cover. Won't hurt it but will need oiling regularly. Quote Link to comment Share on other sites More sharing options...
flight1 Posted March 23, 2022 Author Share Posted March 23, 2022 yes could be a situation of making one up, i have looked for magnum parts, I am sure something will turn up, just got to keep asking around you never know Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted March 24, 2022 Share Posted March 24, 2022 Hope you find tye parts. As you say there must be loads lying around. Whenever I try to buy old fourstrokes for spares many of the owners seem to think they are made of some sort of precious metal whereas they willingly dispose of two strokes . Quote Link to comment Share on other sites More sharing options...
Jon H Posted March 24, 2022 Share Posted March 24, 2022 What happened to the old rocker cover? If its got a hole in it from a broken rocker adjustor you can normally fix them up with car body filler and some coats of black engine enamel. I have rescued 2 or 3 rocker covers like this before. Quote Link to comment Share on other sites More sharing options...
flight1 Posted March 24, 2022 Author Share Posted March 24, 2022 well the filling the whole in the old cover should be suffice i have a small bit of Jb weld laying about should do the trick. and yes the locking nut some how got loose and the tip of the tappet screw broke off (just the bit with the slot cut in), Quote Link to comment Share on other sites More sharing options...
Andy Gates Posted March 24, 2022 Share Posted March 24, 2022 If only the tip of the tappet had broken off, remove it and using a dremel type tool cut a groove in the threaded bit. Reassemble and the tappet can be adjusted with a small screwdriver and still be locked out with the nut. Quote Link to comment Share on other sites More sharing options...
