Zflyer Posted April 7, 2022 Share Posted April 7, 2022 I have saito FA62 and the slider is seized in the barrel. (Its in a puppeteer which I bought 2nd hand and as been in my loft for three years. I havent flown it yet) I have soaked it in WD40 to no effect. It is currently soaking in vinegar.. I was considering dropping in a pan of boiling water but am concerned about the rubber gaskets. Anyone have a useful tip i can try? Quote Link to comment Share on other sites More sharing options...
Jonathan W Posted April 7, 2022 Share Posted April 7, 2022 Vinegar = acid = bad idea! Boiling water should be fine, very good chance to free the gummed up carb. Rubber parts will be OK at that temperature. Best not to use a heat gun because then you could burn the rubber. 1 Quote Link to comment Share on other sites More sharing options...
Nigel R Posted April 7, 2022 Share Posted April 7, 2022 Just soak the whole carb in old fuel for a week or two. 1 Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted April 7, 2022 Share Posted April 7, 2022 Hot water, alcohol or acetone, a heat gun also works wonders, it's the oil ( castor ? ) making it stick it just needs loosening up. Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted April 7, 2022 Share Posted April 7, 2022 apply some heat with a hot air gun or hair dryer...and a bit of oil.. ken anderson....ne...1... heat dept.. Quote Link to comment Share on other sites More sharing options...
Zflyer Posted April 7, 2022 Author Share Posted April 7, 2022 Sorted, in a of pan boiling water. Thanks for the help gentlemen. 1 Quote Link to comment Share on other sites More sharing options...
