Glider ID please…ah! it's a Centiphase
Hi chaps, hope you can help.
I’ve acquired this 3-channel glider from a dec’d club member’s model sale, but don’t know the name. It has a glass fuselage and foam/veneer wings. I’d guess it’s 1980s vintage, but perhaps you’d know for sure. All-moving stab, span is 100”. Tow release on the underside.
  • Like 4
Very nice David.
The tailplanes are on upside down, there is a cut away section at the front that allows clearance to the fin at full up elevator.
I have two flying Centi-Phases (one with foam wings, one with built-up wings), one wooden fuselage build in progress and years ago I was given a CP but wrote it off on the slope (bottom landing).
From a scrap CP fuselage I built a Hi-Phase, later Hi-Phases had their own fibreglass fuselage.
        Gary
  • Like 2
The Centi-Phase kit (glass fuselage/foam wing) was reviewed in the May 1979 'Radio Modeller', the kit was released in February.
Prior to that 'plan packs' were available, wing ribs (in a sandwich), hardware and a plan. My white CP was built using a kit fuselage and plan pack wing ribs.
The built-up wing version is much lighter and is better for flat field flying, the foam wing version is very nice on the slope in a light to moderate breeze.
There could be one or two main wing joiner rods, stacked. The double rod was advised for 'enthusiastic flying' and tow/bungee launches in windy conditions. My white CP has only one rod to keep the weight down and I also only launch it with thin surgical tube bungee on light wind days. If you leave out the smaller incidence pin wire it will behave very strangely, ask me how I know!!
This model has self-connecting Graupner spoilers (No 93), they are operated by the white plastic fitting which is a torque tube in the fuselage.
  • David Ashby changed the title to Glider ID please…ah! it's a Centiphase
She’s flown. Gusting 15mph but the model felt comfortable after a little trimming and acclimatisation. I may move the C of G forward a little but I’ll fly it on a gentler day first before doing anything.
As you said Gary, landing needed some care, but our slope has a large landing area that gave time and space to lose height in a less turbulent space. Other flyers loved the groovy wing decoration ?
  • 1 month later...
7 hours ago, John Minchell said:
Nice Centi Phase David, but I am really interested in the tail less swept flying wing in the same picture - any details please?
You can PM me so as not to hijack the thread onto a different topic.
Thanks John M
It’s an own-design from my slope flying buddy Paul. Must be around 3m span but that’s all I know.
His excellent blog is here if you want to make contact: http://goodwindsoaring.blogspot.com
