Gary Clark 1 Posted May 14, 2022 Share Posted May 14, 2022 I have tried to bind my Futaba receivers to my transmitter and both receivers go solid green after pressing the easy link button but the servos don't move. Anybody with FASST seen this before? Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted May 14, 2022 Share Posted May 14, 2022 Is your gear ticked as comparable on these charts Gary Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted May 14, 2022 Share Posted May 14, 2022 (*)(**) Set the transmitter's modulation as "PPM" to use the TM-7, TM-8.(**) With selection of "7ch" or "8ch" mode via switch, the receivers above listed are available.With R6014FS, available channel is limted as 8ch since the transmitter's limitation. With T7U, the R608FS and R6014FS are available with "8ch" mode but available channel is limited as 7ch since the transmitter's limitation Quote Link to comment Share on other sites More sharing options...
Gary Clark 1 Posted May 14, 2022 Author Share Posted May 14, 2022 Thanks Dennis, that's answered the question on the R606, it is compatible ?. I have 2 R617s and 1 binds fine and the lther does the solid green but no servo movement. So confusing Quote Link to comment Share on other sites More sharing options...
kc Posted May 15, 2022 Share Posted May 15, 2022 Of course servos don't work if plugged in the wrong way round which is easy to do if they are the type without a tab on the side. Quote Link to comment Share on other sites More sharing options...
