ARC Posted September 20, 2022 Share Posted September 20, 2022 Has anyone got the 70-91 version, looking to see how folks got round the wing fixings scenario 1 Quote Link to comment Share on other sites More sharing options...
J D 8 Posted September 20, 2022 Share Posted September 20, 2022 Don't know what you mean by ' wing fixing scenarios ', clubmate has one with a Laser powering it. Lovely flyer and goes in his car in one piece. Quote Link to comment Share on other sites More sharing options...
ARC Posted September 20, 2022 Author Share Posted September 20, 2022 what car has he got ? The top wing attaches with bolts and blind nuts , most that have to remove for transport complain the threads give out after a while Quote Link to comment Share on other sites More sharing options...
john davidson 1 Posted September 20, 2022 Share Posted September 20, 2022 Mine goes in in one piece-just (X-Trail) The top wing halves are held in place on the carbon rod by white sticky tape, holes in the fuse side to access the screws for the cabane. The bottom wing is accesssed by removing the cockpit It is a tough structure, I have cartwheeled it at least twice on landing with no damage, it has to be flown on under power to maintain rudder authority . Same on take off, keep the nose level , if you lift off too soon it turns smartly, usually hard left . good training for your left thumb. As already said a lovely flier, once you get it up there Quote Link to comment Share on other sites More sharing options...
ARC Posted September 21, 2022 Author Share Posted September 21, 2022 Thanks John , I've a skoda karoq so might get away with. Did you find you need any rudder mix on the ailreons? Quote Link to comment Share on other sites More sharing options...
john davidson 1 Posted September 21, 2022 Share Posted September 21, 2022 I don't use mix, I also fly a 3D which gives plenty left thumb practice on rudder. I could see it being helpful though, a touch of rudder does bring the nose round better, you certainly know if the rudder is out of trim Quote Link to comment Share on other sites More sharing options...
ARC Posted October 10, 2022 Author Share Posted October 10, 2022 Hi John , how did you find the 11cm from front of top wing for the c of g , just right or needed to come forward a little ? Quote Link to comment Share on other sites More sharing options...
john davidson 1 Posted October 10, 2022 Share Posted October 10, 2022 I just went out and measured , it is exactly 11cm behind front of top wing.I bought it from a deceased clubmates estate and either him or me actually has it marked at 11cm. Flies perfect at that once off the ground! Quote Link to comment Share on other sites More sharing options...
john davidson 1 Posted October 11, 2022 Share Posted October 11, 2022 Also, just returned from a test drive of the new electric Qashqai (with petrol generator) ,no X-Trail available yet, comparing it with my X-Trail the hatch is very much smaller, so changed my mind and will wait . My mate has a Karok and it certainly has a wide opening so I think you will be ok. Quote Link to comment Share on other sites More sharing options...
ARC Posted October 12, 2022 Author Share Posted October 12, 2022 thanks John much appreciate the info. I'm not impressed with how the top wing is secured. If it fits in your car in one piece did you consider epoxying the upper wing halves together with the balsa connector for the central strut? Quote Link to comment Share on other sites More sharing options...
john davidson 1 Posted October 12, 2022 Share Posted October 12, 2022 No white sticky tape does the job, never thought of glue Quote Link to comment Share on other sites More sharing options...
ARC Posted October 12, 2022 Author Share Posted October 12, 2022 think I'm going to try in my car in one piece , if it goes in i'm going to glue the top wing halves together. Quote Link to comment Share on other sites More sharing options...
john davidson 1 Posted October 12, 2022 Share Posted October 12, 2022 (edited) Cartwheeled it on landing a few times, the tape might give a bit of absorption , amazing no damage has resulted. Tough bird. Also hit the electric fence with the legs once It has dural legs and which bend badly on every landing and maybe contribute to the behaviour, found a set of composite ones in the depth of the shed today , try them for size on Friday Edited October 12, 2022 by john davidson 1 addition Quote Link to comment Share on other sites More sharing options...
