Stephen Jones Posted October 20, 2022 Share Posted October 20, 2022 Just thought I'd share how I cut holes in Balsa ribs. I sharpen the end of a suitable size brass tube. Steve Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted October 20, 2022 Share Posted October 20, 2022 Rather than sharpen the end of a brass tube, I file teeth into it and either turn it by hand or by electric drill. I also use it to form a long hole in a foam wing core for lighting or servo cables. 1 Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted October 21, 2022 Share Posted October 21, 2022 Harder woods heat the tube up with a blowlamp, and for servo wires in foam or balsa wings a 4mm length of piano wire again heated up with a blowlamp, attention in foam it will make a 5/6mm hole so you can go down to 3mm. Quote Link to comment Share on other sites More sharing options...
