Spektrum AR610 alternative?
Thank you!
All seems sorted now, it was 'operator error' ( of course).
I had the ex connected to the esc in the Battery position, not throttle position...
with all other controls disconnected, just the esc lead to the Throttle  pin 1, followed the advice on here and all is correct.
Throttle all works, and have all the control surfaces all responding correctly by orientation.
Juat have to set the movement ranges now as all surfaces move at least 45 degrees which would make for a wild flight..
As ever, thank you to all and your patience in helping a novice get sorted.
Really like this plane.
Doubt I will get it into the air this year, but taking it to the field tomorrow for my buddy man to look over and advise on surface movement.
I am about to set the ele/ alien to the same ish movement as the Kingfisher making an assessment of the Kingfish surface area v this SU 26m's areas.
Going for about 5 to 8 degrees both ways, hope that will be about right for my skill base.
