Wanted OS .46LA
cymaz
Don't mean to be negative, but I think you might struggle a bit with that. I have a little used 40LA and the liner plating is peeling off. I guess the 46 will suffer similar issues. If you want a simple plain bearing 40 size engine, can I suggest the Enya SS40 ? They probably have as much power as a 46LA and a very durable iron piston. The SS40 comes up quite often on eBay and no doubt elsewhere.
