Elfin 2.5 ED racer Allbon dart repair
jeff2wings
Got these last year so before I start my next balsa butchery project it's repair time  !
dart in need of anew crankshaft, conrod, prop driver, backplate
Elfin in need of a new conrod and wrist pin
ED racer in need of new bearings, resized piston (low compression) stripped thread repair repaint case modify crankshaft
So this afternoon made a new conrod and wrist pin for the Elfin
classic dogbone made from T6 end journals roughed out and finished with a file, wrist pin made from silver steel
new rod with old one and pin
all ready for a test run
  • Like 4
While I'm saving up for the bearings for the racer started on the dart,this will be more of a custom built rather than a restoration due to missing/damaged parts
Roughing out the crankshaft
blank ready for machining the crankpin
New backplate mounting
As  can be seen the mounting lugs are damaged so I will probably remove them
Jeff, Just my humble opinion. The work looks great, but the Racer case would be much better left natural magnesium, rather than painted (yuk!).
I have several newish originals, and most are losing their original black coating to varying degrees.
Personally, I much prefer an "original" look to a restored and repainted look...
Hope this doesn't upset you too much.......
This will most likely go in a bluepants or KK scout team racer sonot to much poking out
I'm not sure but I think the black coating was a kind of anodising that protects the magnesium case from corrosion, a common problem with ED's and Mills best thing is to keep the outside oiled (by running them!)
think I may remake the backplate with a tank in the style of Cox bee
Edited by jeff2wings
Hi Jeff the black coating was I believe a chromate treatment to prevent corrosion. I have restored some old Mills in the past and as Chromate wasn't an option I found that a thorough clean and degreasing followed by a thin coat of matt black sprayed on . Then a good soak in some oil gave a good rendition of the riginal finish that has lasted well with no signs if the white powder corrosion re occurring. The Racer case look fine to me. A wipe over with an oily rag and it will pass muster😉
