Fitting Digital Servos To My Entry For La Coupe Des Barons.
David Davis
On 04/04/2023 at 08:23, David Davis 2 said:
How do I check the frame rate Frank on my Spektrum DX9 Frank?
David, I don't have a Spektrum Dx9, but it looks like it is on page 18 of the manual
It even says to select 22ms if you use a mix of analogue and digital and 11ms for digital only. There is no harm using digital servos at a 22ms frame rate and I doubt the Coupe de Barons model would benefit from the higher update speed, even in the pylon race.
From memory, when you bind , it defaults to 22 ms, ther is an option to change to 11ms then.
