Andrew Calcutt Posted March 5, 2023 Share Posted March 5, 2023 I have a tank with 3 outlets,my silencer has no nipple on it,would you blank one tube off.Engine is a saito 40 fg. Quote Link to comment Share on other sites More sharing options...
David Davis Posted March 5, 2023 Share Posted March 5, 2023 Lasers have no pressure nipple on their silencers either but they run well. If I were you, I would blank off one of the pipes from the tank and see how it works in the air. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted March 5, 2023 Share Posted March 5, 2023 Petrol needs a vent for the fuel to flow from the tank Andrew Quote Link to comment Share on other sites More sharing options...
Don Fry Posted March 5, 2023 Share Posted March 5, 2023 (edited) Don’t see how that works, filling would drive the tank air/fuel splutter through the motor, and you end up with an unknown fuel load in the motor. Pipe one, engine feed. Pipe two, vent. Pipe three, fill. Blank fill pipe off after fill. I see Denis has a diagram. I was referring to a 2 pipe system Edited March 5, 2023 by Don Fry Quote Link to comment Share on other sites More sharing options...
