Andy Stephenson Posted April 24, 2023 Share Posted April 24, 2023 Can anyone help. I am installing this ESC in a glider and I want to make sure the brake is active so the folding prop folds when it should. Does anyone have a copy of the instructions for this ESC as it seems to be obsolete these days. Thanks, Andy. Quote Link to comment Share on other sites More sharing options...
J D 8 Posted April 24, 2023 Share Posted April 24, 2023 If it conforms to the pretty standard set up for BEC's then after entering the programing mode with the throttle stick up and the tones are operating it is when the single beep is heard brake is entered, move throttle to bottom with in 3 seconds and it is then selected. hope this helps and watch that prop. Quote Link to comment Share on other sites More sharing options...
Andy Stephenson Posted April 24, 2023 Author Share Posted April 24, 2023 JD, thanks I agree they mostly have very similar firmware but exactly when the brake setting is signalled would be useful as I could end upsetting the timing or some other thing. Yes, always remove the prop when setting the ESC, most important. 1 Quote Link to comment Share on other sites More sharing options...
