Order of applying covering film
I'm still somewhat of a novice where covering a model is concerned, having completed three builds in the last few years.  I'm at the covering stage with a Black Magic build and I'm using Oratex to achieve a fairly simple black and gold (well, yellow really!) scheme.
The fuselage will be yellow top half and black bottom half.  I know the general rule is cover bottom first, then sides and finishing with the top.  But I think the rule is also cover light colours first and overlap with darker.
So.... is it "acceptable" to cover the top half of the fuse sides with yellow first and follow with the bottom half (after the underside is done) in black?
Advice and comments very welcome.  Thank you.
