Nigel Dell Posted August 5, 2023 Share Posted August 5, 2023 On 03/08/2023 at 15:25, Ron Gray said: @Nigel DellAre they really 500g for the pair? Ron, just weighed the parts and they come to 488g so pretty much, very substantial with moulded tyre that is sandwiched between two side frames and bolted together with aluminium spaces so will look into saving weight although on the SE5 probably not necessary, I think these were designed for the Sopwith kits so will withstand an earthquake 😂 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted August 5, 2023 Author Share Posted August 5, 2023 Thanks Nigel, the H9 DVII is listed at an auw of approx 12Kg so what's a few G extra going to make, plus it will be in front of the C of G which could also help as it would seem that, depending on engine, quite a bit of lead maybe required in the nose. Quote Link to comment Share on other sites More sharing options...
Kevin Fairgrieve Posted August 5, 2023 Share Posted August 5, 2023 What diameter are they @Ron Gray? Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted August 5, 2023 Author Share Posted August 5, 2023 (edited) ¼ scale Kev, so approx 7" Edited August 5, 2023 by Ron Gray Quote Link to comment Share on other sites More sharing options...
Kevin Fairgrieve Posted August 5, 2023 Share Posted August 5, 2023 OK, so the above are 6 1/2 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted August 5, 2023 Author Share Posted August 5, 2023 In that case I could well be interested. Next time we're out flying could you bring them please?s Quote Link to comment Share on other sites More sharing options...
Kevin Fairgrieve Posted August 5, 2023 Share Posted August 5, 2023 No Problem. Quote Link to comment Share on other sites More sharing options...
