leccyflyer Posted September 16, 2023 Author Share Posted September 16, 2023 10 hours ago, Richard Acland said: Bought one of the drills today. Plugged it in to a USB charger rated at 5v 2A. The USB charger became very hot, in fact so hot that I unplugged it. I assume I need to get a USB charger rated at 4A to be able to charge it. Not according to the manual, which recommends a charger of <4A - with a lower amperage it will just take a little longer. I've charged mine with the wee wall wart that charges my cordless glue gun [email protected] and with the accessory USB-A output of a spare laptop charger -5v@1A. Quote Link to comment Share on other sites More sharing options...
Tom Gaskin 1 Posted September 17, 2023 Share Posted September 17, 2023 I charge mine from the usb outlet ihat are integral with our kitchen wall sockets - they are rated at 5V 2.1A and didn't appear to take too long to charge it to 'green light' Tom Quote Link to comment Share on other sites More sharing options...
John Lee Posted September 17, 2023 Share Posted September 17, 2023 On 15/09/2023 at 22:24, Richard Acland said: Bought one of the drills today. Plugged it in to a USB charger rated at 5v 2A. The USB charger became very hot, in fact so hot that I unplugged it. I assume I need to get a USB charger rated at 4A to be able to charge it. On 15/09/2023 at 22:33, Philip Lewis 3 said: USB C isn't always 5 Volts, my laptop USBC intelligent charger is 19 volts, stupidly I lost the charger that came with mine so now have to charge it with my normal chargers (which means taking it appart), it won't charge off 5 volts though but can't remember what I used without taking it appart again. USB-C have the option of four different charging voltage levels of 5V, 9V, 15V, and 20V. The charger & device should shake hands on connection so that the the correct voltage & amperage is recognised. It sounds like the correct protocol is not being exchanged between the charger & drill in Richard's case, but without proper testing or substitution you can't know which is at fault. Quote Link to comment Share on other sites More sharing options...
