Graham Bowers Posted October 6, 2023 Share Posted October 6, 2023 I have the kit and am pulling together the other bits I'll need. I was umming and arring about IC vs electric however having read through earlier posts I see @RICHARD WILLS stated "The electric version is far better........." so that's the way I'm leaning. I'm now wondering about battery size and flight time. I'd really like 8 minutes however see Richard also commented a 3300 mAh 4S gives about 5 mins. I see @Dickwused 3700's and @David Hazell 1used 5000's. I realise flying style has a lot to do with it, however I do modulate the throttle! What's current thinking on flight times and flight performance with the bigger batteries please? Accepting there's a limitation on fitting them in. I'd need to buy whichever batteries I go for as at 4S I have a couple of 2200's and a couple of 2600's. I see motors are showing out-of-stock on the WR replicas website at the moment. Any recommendations for a substitute please? Thanks Graham 1 Quote Link to comment Share on other sites More sharing options...
Graham Davies 3 Posted October 7, 2023 Share Posted October 7, 2023 Hi Graham, Definitely go electric; it makes painting SO much easier! I have a Tempest and use a 4250 size motor of around 560 or 600kv (can't remember now!) which turns a 14x6. I use 4S 3700 packs and get 7 minutes with some reserve flying in a scale manner. The motors are freely available on Ebay, but not as cheap as they were. Good luck Graham 1 Quote Link to comment Share on other sites More sharing options...
David Hazell 1 Posted October 7, 2023 Share Posted October 7, 2023 I ended up running on 3300 4S as the plane balanced out way nicer! I would say I'd get about 6-7 mins... 1 Quote Link to comment Share on other sites More sharing options...
Jonathan S Posted October 13, 2023 Share Posted October 13, 2023 Graham, I am going with Pauls recommendation, predator 4250 580KV motor with probably a 3300 4s. I am have the wings together and the fuselage is getting there. you will love it such a fun build. Jon 1 Quote Link to comment Share on other sites More sharing options...
Graham Bowers Posted October 14, 2023 Author Share Posted October 14, 2023 Thanks for all replies. 4250 580v motors seem a bit thin on the ground right now. I discussed with Richard and eventually decided to go with an 800Kv version and prop accordingly. As regards batteries, I have 2200 4s and 2700 4s already. I'll probably conduct initial flights with 2700' 4s's, lead to suit, and take those flight times in to account. Before I build the fuz I'll shortlist some bigger battery candidates and see what adjustments can be made to the battery compartment. Quote Link to comment Share on other sites More sharing options...
