Mikenotts Posted December 10, 2023 Share Posted December 10, 2023 This will be my 1st build blog. As I could find no other builds for this model it will have to follow the line of flexibility. Also having no natural slopes and had enough of catapult launches, it will have retractable landing gear and rudder with stearable tail wheel. These mods are going to add weight in wrong place so I will start by assembly of basic fuse then wing to find out how many liberties I can take with said undercarriage and tail assy. In addition I have boxes of parts from previous planes, retracts for example, I have 3 working sets of retracts for planes up to 2kg that will be used. Looking to finish with AUW of 1.6 kg. First decision which battery, well I have 3 cell, 2200mah, 4000mah and 4 cell 2200, 300, 3300,4000.....need to make model able to accept any of these, as which to use will be governed by trying to achieve CofG without adding weight to nose. First job mod battery box to accept any of above batteries. Glued in 3 mm and 4 mm strips to give battery box internal dimension 52mm wide 28mm high. The 2 battery box support formers will need careful modification to accept these mods 2 Quote Link to comment Share on other sites More sharing options...
Cliff Bastow Posted December 10, 2023 Share Posted December 10, 2023 Mike, I have one of these. It was not the easiest kit I have ever built. The tail and elevator mechanism is a bit fiddly to say the least. I had to fit quite a bit of nose weight to get it to balance and I have the battery as far forward as I could get it. The end result looks good though and it flies really well and looks great in the air. Any help I can give please feel free to ask. Cliff. Quote Link to comment Share on other sites More sharing options...
Cliff Bastow Posted December 10, 2023 Share Posted December 10, 2023 1 Quote Link to comment Share on other sites More sharing options...
Mikenotts Posted December 11, 2023 Author Share Posted December 11, 2023 Cliff, Thanks for update, I am hoping that the combined weight of motor, ESC and retracts in front of 55mm balance point will allow me to get CogG without extra weigh in nose. There is one question though, in the absence of a drawing, and going by specs for full size plane, wing appears to be at 1 degree incidence so I will be making tailplane 0 degree to maintain said decalage (longitudinal incidence). Going to use a straight edge to get tailplane parallel to top of fuse sides. How did you set yours up?. All my previous builds have been traditional ply and balsa, TN hurricane, spitfire,lancaster to name a few, never used veneered foam before, so the is a big learning curve for me. The first thing I did before starting was to experiment with different glues, zap a gap for balsa, ok . For balsa and foam PVA but not on highly stressed parts, now comes the tricky bit glueing foam to join wings etc, tried most things, hot glue, the 5 minute epoxy, super glue ALL melted foam. Was about to shell out on foam safe epoxy,.....but... Its very expensive. In desperation tried some epoxy from a £1 store (okay it cost £1.50 ) and this stuff works great, it takes 30 mins to start to go off, needs to be left in warm place to cure but sets rock solid and very strong, picture to follow. Thanks Mike Quote Link to comment Share on other sites More sharing options...
Mikenotts Posted December 11, 2023 Author Share Posted December 11, 2023 Been a good day today 10 degrees,warm enough to work in unheated garage. Built the fuselage as described in instructions. Scaled instruction picture of fuse to give position for spacers, added fin assy and promptly broke it bring clumsy so rebuilt it and added balsa sheet to give it mechanical support while I work on fuse. Cut away last part of top deck moulding making it easier to fit. Offered up top deck moulding. But very difficult to work out where to cut it as it keeps moving. Cut some foam supports from scrap foam and glued these to top of spacers and former, rubbed them to shape to support moulding, now have contact at front, rear and above spacers and former, moulding nolonger moving, so drew line with straight edge and cut to just fit. Top deck held in place at moment with rubber bands. Next will be wing, I am working towards being able to rough assemble everthing to see if balance is going to be an issue. Quote Link to comment Share on other sites More sharing options...
Cliff Bastow Posted December 11, 2023 Share Posted December 11, 2023 Mike, As far as I can remember the tailplane is set at 0Deg incidence. I think this is set by the support plate which sits between the front and rear fin posts. I used foam safe epoxy for the wing joints. I could scan my instructions and message you a copy if it helps. Quote Link to comment Share on other sites More sharing options...
Cliff Bastow Posted December 11, 2023 Share Posted December 11, 2023 Mike, I remember the top decking being difficult to make fit at the rear end. I ended up cutting it in front of the fin and cutting the rear part in half along the top and fitting each part seperately. Quote Link to comment Share on other sites More sharing options...
Geoff S Posted December 12, 2023 Share Posted December 12, 2023 15 hours ago, Mikenotts said: Cliff, Thanks for update, I am hoping that the combined weight of motor, ESC and retracts in front of 55mm balance point will allow me to get CogG without extra weigh in nose. There is one question though, in the absence of a drawing, and going by specs for full size plane, wing appears to be at 1 degree incidence so I will be making tailplane 0 degree to maintain said decalage (longitudinal incidence). Going to use a straight edge to get tailplane parallel to top of fuse sides. How did you set yours up?. All my previous builds have been traditional ply and balsa, TN hurricane, spitfire,lancaster to name a few, never used veneered foam before, so the is a big learning curve for me. The first thing I did before starting was to experiment with different glues, zap a gap for balsa, ok . For balsa and foam PVA but not on highly stressed parts, now comes the tricky bit glueing foam to join wings etc, tried most things, hot glue, the 5 minute epoxy, super glue ALL melted foam. Was about to shell out on foam safe epoxy,.....but... Its very expensive. In desperation tried some epoxy from a £1 store (okay it cost £1.50 ) and this stuff works great, it takes 30 mins to start to go off, needs to be left in warm place to cure but sets rock solid and very strong, picture to follow. Normal epoxy resin is safe on foam but the cheaper polyester (like David's Isopon) isn't. Epoxy resin has little odour but polyester has quite a strong smell. I use West for some jobs but most often Zpoxy at various speeds but most commonly either 30 minute or 5 minute (the former is better IMO). None of them attack foam, though they are more expensive than polyester. Quote Link to comment Share on other sites More sharing options...
Mikenotts Posted December 12, 2023 Author Share Posted December 12, 2023 Hi Geoff, Not tried that particular epoxy, having built mainly from wood have tried to avoid epoxy in past, due to it being heavy and other cheaper options work better with balsa/ply. When I did use it on some foamy planes it was the stuff from HobbyKing typically 5 min, but cannot get that now and with all other sources drying up its left to by on internet. The stuff I bought from ebay was 5 min and worked on a foamy I had, but not this foam. I think the issue may be time some 5 min epoxy generates heat as part of curing, and that can melt some types of foam. The glue I got for £1.50 takes forever to go off but no heat. As I had not worked with this particular foam before tried to find cheapest option that works, other epoxies will no doubt do job but cost more, oh and this stuff does not smell. Regards Mike Quote Link to comment Share on other sites More sharing options...
Mikenotts Posted December 13, 2023 Author Share Posted December 13, 2023 Got a couple of 2836/07 1100kv motors that are slightly larger than the 4 I fitted to the TN lancaster, they should be okay. Got both 30 amp and 40 amp ESC 's in my bit box will go with 40 for time being. The retracts are from foamy spit/P40. The nacelle crutch to support this hardware will be based on lancaster pattern, still got drawing of those to copy from. Main decision is where to put ESC's, best place is in nacelle which has decent airflow, but that means lengthening power cables. Whilst on Lancaster I fitted 470mf 25v capacitors next to each ESC, to cancel out spikes which can cause premature failure, these were quite long extensions. If can keep power extension to under 150mm on 3s (12v) it will be okay but if need to go to 4s will need these capacitors. Built wing generally as described marked out where nacelles will go, but only glued 3mm infill to slot between outer edge and nacelle and in center section. This will leave a open bit between nacelle and center to allow all these extra cables to be managed. Contructed nacelle crutches and glued directly onto wing, trial fitted motors, and retracts and fitted ESC power cables in cut slot as described in instructions. Used XT30 power connectors they will be okay with calcullated load, and there is not enough room for XT60's without lengtening cables. Quote Link to comment Share on other sites More sharing options...
Mikenotts Posted December 18, 2023 Author Share Posted December 18, 2023 Next job glue wing tips to central section, as this epoxy takes so long to go off it will need mechanical support to align and locate wing tips and an elastic bungee cord to hold everything together whilst it sets. Fitted a couple of pieces of carbon fibre tube into wings, made a template to give a 3 degree angle, drilled central section at 3 degrees to top of wing and wing tip parallel to top, this will, if my calcs are right give 35mm af dihedral at wing tip. Glued 1 CA tube in 1 half and 1 in other . When dry test assembled to check dimensions, all okay so glued together. Quote Link to comment Share on other sites More sharing options...
Mikenotts Posted December 27, 2023 Author Share Posted December 27, 2023 Started to assemble wing parts motors fitted, ESC's and clockwise and counter clockwise 3 blade 9x4.5 inch props. Glued plastic naceele covers together, decided to make them removeable, so back portion is glued to wing, front portion held with single screw. Only 1 spring undercarriage leg arrived so on hold till other arrives. Quote Link to comment Share on other sites More sharing options...
Mikenotts Posted January 11 Author Share Posted January 11 Okay other U/C leg arrived, fitted complete wing to fuselage. There appears to be enough weight in wing assemby to allow a certain amount of freedom with tail. So as room is very tight arround front of fuse decided to make load bearing part of tail support out of 1.5 mm balsa and fit a 9 gram mg elevator servo directly in tail, this makes things very simple and positive. Fitted another servo in fuse for combined rudder and tail wheel. To cut down on weight all non load bearing parts ie rudder, vertical tailplane front edge and tail top fabricated from foam. Checked balance and very little lead will be required, in fact we are just nose heavy, but lets see where we are after a base coat of paint.! 3 Quote Link to comment Share on other sites More sharing options...
Mikenotts Posted January 17 Author Share Posted January 17 Slight setback, whilst setting up rudder and elevator noticed light on receiver flickering when operating servos, traced to onboard receiver BEC , it's linear and not up to job. Was going to fit a seperate UBEC as I did on Lancaster, but didn't have one handy so went with esc bec, mistake, one on order but where to put it , going to add extra weight in wrong place, just when I had CofG just right with minimum extra lead. Well cannot be helped, will see how it affects balance when it arrives. Quote Link to comment Share on other sites More sharing options...
Mikenotts Posted January 23 Author Share Posted January 23 Whilst waiting for UBEC to arrive ran numbers through a CofG calculater , wanted to know what effect my increasing tailplane area would give. To give a more scale view of tailplane glued a 4mm strip to tailplane and 9mm to elevators to give a shape as shown in attatched scale drawing. Figures for original tailplane give CogG 55 mm from leading edge. With the increase to overall width by 13 mm gives a CofG from leading edge of 58.5mm. This is good news, it gives me a lot more flexibility on where to put UBEC. Quote Link to comment Share on other sites More sharing options...
Mikenotts Posted February 23 Author Share Posted February 23 Fitted ubec power supply, cut both red wires to ESC's so there is no voltage conflict. Its very tight in front end, but it all fits in. Final assembly. Total weight and that includes a 4000mah 3s lipo for motors and a 500mah 2s lipo for ubec, power to servos and receiver, 1.760kgrams. (1760grams). Center of Gravity 58mm from leading edge, which should be ok with the mods to tailplane. Took some photos, but these were indoors as its still raining. Will have to wait for grass at our runway to be cut, oh for it to stop raining before I can maiden it. But retracrs work and does rudder and tailwheel steering......roll on spring. 8 Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted February 24 Share Posted February 24 Good job! Quote Link to comment Share on other sites More sharing options...
Andrew Douglas Posted April 4 Share Posted April 4 Very nice job , I have a DH88 kit to build but thinking of getting one of these now also. How did it maiden ? Quote Link to comment Share on other sites More sharing options...
Mikenotts Posted April 4 Author Share Posted April 4 Hi Andrew, Not flown yet. Our field is still too wet and the mower man says he will sink in and leave ruts! I will let you know when and if it survives maiden flight. The Westland Whirlwind I have built is quite modified , this kit after all is sold as a PSS unit i.e slope soarer. Mine has rudder, stearable tail wheel, and retracts. Also because there is quite a lot of weight forward it allowed me to put a servo directly in tail assy for elevator, instead of the S snake arrangement. Rgards Mike Quote Link to comment Share on other sites More sharing options...
Mikenotts Posted May 2 Author Share Posted May 2 Had to add an extra 30 gram to nose, it flew well,landing okay but I allways land warbirds a little hot to avoid potential till stalls. Had about 12 flights, all okay, loops. rolls, split s all ok, but this plane wont fly on 1 motor, found out hard way. Had been flying for about 5 mins when 1 motor stopped , not quick enough to stop other motor tried to recover, too late broke wing, not repairable. But it looked good in air. Quote Link to comment Share on other sites More sharing options...
