Zorba Posted April 25 Share Posted April 25 Hello, Does anyone know of a transparent template making material that can be scored and snapped out, similar to an American product called See Temp? With the above you basically placed over your plan and traced over/scored with a sharpie halfway through and the part just snapped out of the sheet saving a lot of time. I’ve tried quilting template stuff but it’s not the same as it must be traced, removed from the plan and cut with scissors. Jack Quote Link to comment Share on other sites More sharing options...
Geoff S Posted April 25 Share Posted April 25 Never heard of anything like that. If you have access to a pdf file of the plan then most (all? but certainly Foxit and Adobe) pdf viewers allow you to select part of the drawing (a rib, say) and print that. Then it's just a matter of sticking it onto either the wood itself or a something like aluminium to make a template to cut ribs (say). No tracing needed and potentially easier and more accurate. Quote Link to comment Share on other sites More sharing options...
Zorba Posted April 26 Author Share Posted April 26 Okay thank you. I have been doing that in the past as well. I just thought that by scoring directly over the plan it would save time. Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted April 26 Share Posted April 26 With formers I usually use the age old technique of pricking out the shape through the plan directly onto the wood, then just join the dots with a scalpel and straight edge (steel rules). With ribs I prick out onto a piece of thin ply, carefully cutting round it into the wood as a template. OK on a parallel chord wing. Quote Link to comment Share on other sites More sharing options...
Matt Carlton Posted April 26 Share Posted April 26 For what it's worth, I just use tracing paper. Trace the parts with a thin sharpie or rotring pen. Cut out, glue the paper pattern to the wood with pritt stick and draw around it with a pencil. Then just cut to the inside of the pencil line. Quote Link to comment Share on other sites More sharing options...
Don Fry Posted April 26 Share Posted April 26 19 hours ago, Zorba said: Hello, Does anyone know of a transparent template making material that can be scored and snapped out, similar to an American product called See Temp? With the above you basically placed over your plan and traced over/scored with a sharpie halfway through and the part just snapped out of the sheet saving a lot of time. I’ve tried quilting template stuff but it’s not the same as it must be traced, removed from the plan and cut with scissors. Jack Zorba, I think you are describing acrylic or Perspex (same stuff) sheet in Europe. Usually minimum thickness is 1 mm. it would do what you describe the American product doing. I assume you mean the USA 1 Quote Link to comment Share on other sites More sharing options...
Nigel Heather Posted April 27 Share Posted April 27 (edited) 22 hours ago, Don Fry said: Zorba, I think you are describing acrylic or Perspex (same stuff) sheet in Europe. Usually minimum thickness is 1 mm. it would do what you describe the American product doing. I assume you mean the USA It’s not acrylic or Perspex, it is this stuff http://www.rcfoam.com/rc-hobby-tools-/pattern-cutting-templates/rcfoam---cool-tools-p-1001.html No idea where you can get it nor what alternatives can be used though. It possibly is similar to acrylic but this is 0.25mm thick, plenty of places selling that but in smaller sheets, not sure whether it would snap when scored though. Edited April 27 by Nigel Heather Quote Link to comment Share on other sites More sharing options...
Zorba Posted April 27 Author Share Posted April 27 Yes that’s the stuff. I’m based in the UK but a mate of mine in the US mentioned See Temp. So I wondered if we have something similar here. Thanks guys. Quote Link to comment Share on other sites More sharing options...
