Paul Williams Posted February 27, 2009 Share Posted February 27, 2009 Bought one second hand and I cant get the dam thing to do anything. I tried testing the Rx with a sep battery and servo it seemed dead so I fitted another RX (not out of a twister) and got some success. plug in the rudder and throttle plugs and the motors seem to work ok (solid green light on ESC unit) but then should I plug in the two servos it all goes to rat ++++ and green light goes red. I have tried different servos so thats not the problem. Funny thing is just plug in the two servos without esc and they work fine. So its only when all four plugs are connected it wont work. Does the heli have a special RX or should a standard one be ok. Confused Quote Link to comment Share on other sites More sharing options...
Owen Hailey Posted February 28, 2009 Share Posted February 28, 2009 Hi Paul The rx in the sky lift has to control all 4 motors as seprate units, so will be made to suit the sky lift only, and if you use a cx 4 in to 1 I dont think this will work, so as you have found out that the parts all work the only think to do is get a sky lift rx, and I think your problems will be at an end, hope this helps. all the best Owen. Quote Link to comment Share on other sites More sharing options...
Jonathan Lewzey Posted February 28, 2009 Share Posted February 28, 2009 Replace it with a Skylift 4 in 1 unit. And do try and find out if equipment works before buying 2nd hand - i reckon its going to cost you about £40 for a new unit. Quote Link to comment Share on other sites More sharing options...
Paul Williams Posted February 28, 2009 Author Share Posted February 28, 2009 Cheers guys Quote Link to comment Share on other sites More sharing options...
An Engineer Posted March 1, 2009 Share Posted March 1, 2009 Hi, I have most of a couple of these things and I found out real quick that the electronics is, like the rest of it, rather fragile and short lived. I found that the receiver is no great shakes to replace, pretty much any rx/ 4 channel receiver can be made to work O.K. with the "four in one" box, BUT the four in one box can die in the most interesting ways... Mine (when I accidentally put a connection to the receiver in the wrong way round, doh!) started doing exactly what you describe, It apparently worked on occasion but didn't most of the time. It was also very sensitive to how many, and in what order, the leads were connected. I was lucky enough to win the core of a skylift with good electronics, so as I could mix and match,for diagnostic purposes, whilst my 4 in 1 was performing it's dance of death, and subsequently was able to verify that I could use a couple of different receivers to fly my skylift, with the new unstuffed 4 in 1. As someone has already pointed out, a new 4 in 1 box is 30 to 40 quid, and when you get a new one you still have the same lack of quality to contend with, SO, I got seperate components and am currently building a second skylift using a couple of esky esc's a heading hold gyro from ebay, and an "elevon servo" mixing lead. I also will be using a 8 channel receiver (so that I can add a tiny winch and some switcheable lights later...) Early indications are that this lash-up works as I expected, but I need to get some "balance bars" and tidy up the wiring before I can try and fly it... Then I will be looking for some busted servo's to cannibalise for the electronics, to fabricate my winch... Cheers, Steve C. Quote Link to comment Share on other sites More sharing options...
Phil Claridge Posted March 1, 2009 Share Posted March 1, 2009 can i use a 2,4 rx ie spectrum? regards phil Quote Link to comment Share on other sites More sharing options...
Jonathan Lewzey Posted March 2, 2009 Share Posted March 2, 2009 on a skylift? No, the 4 in 1 unit contains gyro and ESCs aswell. Best just to stick with it and get a 2.4 RTF or BNF heli. Quote Link to comment Share on other sites More sharing options...
An Engineer Posted March 2, 2009 Share Posted March 2, 2009 Sorry, my previous posting contains a mistake. My skylifts have a seperate receiver and 3 in 1 not a four in one as I referrred previously. So yes, you should be able to change it for a different receiver I.E. a 2.4Ghz one. Cheers, Steve C. Quote Link to comment Share on other sites More sharing options...
Paul Williams Posted March 3, 2009 Author Share Posted March 3, 2009 I am thinking the 3 in 1 box must be faulty. I have tried 2 different RX's and the unit goes daft as soon as all four plugs are connected. Its fine when just the throttle or just the servos are pugged in but fails when all 4 are ??? Quote Link to comment Share on other sites More sharing options...
simpson j Posted March 4, 2009 Share Posted March 4, 2009 HI skylift to 2.4ghs see chris hornby posting or go to utube john Quote Link to comment Share on other sites More sharing options...
DON WILSON Posted March 8, 2009 Share Posted March 8, 2009 hi guys, similar prob. where do I find 'chris hornby' postings, cant seem to find a link to members to see thier posts. regards don Quote Link to comment Share on other sites More sharing options...
simpson j Posted March 27, 2009 Share Posted March 27, 2009 HI DON GO TO TWISTER SKY LIFT CHINOOK FLYING OUTSIDE BY ALAN B PART 1 SEE CHIRIS POSTING Quote Link to comment Share on other sites More sharing options...
