Shaun Brogdon Posted May 22, 2009 Author Share Posted May 22, 2009 Timbo will be maidening mine tomorrow, im just finishing it now, it came out very tail heavy, i used black tape on the elevons, so perhaps this is the cause? Im still ratching out my scraps of lead to get the CG sorted, and the radio needs setup, but that can be done in the AM. I have pictures, but Wifey has put the card reader in a safe place... Shaun Quote Link to comment Share on other sites More sharing options...
Former Member Posted May 22, 2009 Share Posted May 22, 2009 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Shaun Brogdon Posted May 23, 2009 Author Share Posted May 23, 2009 Finally found the cardreader, so heres some piccys I rushed it together last night for the fly in, but am very pleased with it, goes like stink, & flies v.well inverted. Tim didnt get any stick time as I was enjoying it sooo much i didnt put the tranny down. At the end of the day, I flew it right down off St. Bees head, right across to the golfcourse slopes via the promenade then landed in front of the car park. Id say that makes for a pretty good maiden flight. Shaun Quote Link to comment Share on other sites More sharing options...
Shaun Brogdon Posted May 26, 2009 Author Share Posted May 26, 2009 Some in flight pics for you all Quote Link to comment Share on other sites More sharing options...
Alex Leigh Posted May 26, 2009 Share Posted May 26, 2009 Combat with a wind turbine. Hardcore Nice pics. Quote Link to comment Share on other sites More sharing options...
Dead-stick Posted August 3, 2009 Share Posted August 3, 2009 I've had mine about 6 weeks or so and It really is a great all rounder. Yesterday I was flying in a breeze gusting from 2 - 6 MPH and despite the lack of consistent lift the little W'evo held it's own with some very expensive moulded planes, although it didn't quite have the speed they did! It loops as tight as you like, rolls like a drill and doesn't much care which way up it is. AUW is 386g (13.8 ozs) with 4g of lead ballast in the nose and the paint is Tamiya acrylics sealed with a layer of ClearCoat. What another great foamie from the Richter stable! Edit........See "assorted photo's" link a few posts further down.. (long link deleted.) Edited By Phil Wood - Moderator on 08/11/2009 21:01:47 Quote Link to comment Share on other sites More sharing options...
Martyn Johnston Posted October 28, 2009 Share Posted October 28, 2009 Got a Weasel on order. Read lots of comments on covering it; but not much actual advice. What you think? Paint it? Cover it? what paint? cover it with what? Quote Link to comment Share on other sites More sharing options...
Alex Leigh Posted November 3, 2009 Share Posted November 3, 2009 I just bought a second hand Weasel. Perfect timing for these super light winds we get in Autumn and Winter Ah well at least it's easy to hide! Quote Link to comment Share on other sites More sharing options...
Former Member Posted November 6, 2009 Share Posted November 6, 2009 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Dead-stick Posted November 8, 2009 Share Posted November 8, 2009 Posted by Phil Wood - Moderator on 06/11/2009 18:12:39: Try this.........I've deleted a couple of duff posts / links Dead- stick. is this what was meant to show in the above links? Assorted Photo's Polyphilla. Edited By Phil Wood - Moderator on 06/11/2009 18:16:09 Gotcha! Thanks for that! Quote Link to comment Share on other sites More sharing options...
Alex Leigh Posted November 16, 2009 Share Posted November 16, 2009 I didn't buy an evo! I bought the one before, looks the same but covered in tape/one piece like a WT. Flew it yesterday wow super aerobatic once I'd tamed it. Bit tail heavy at first and it was all a bit roller-coastery for 5 minutes. Anyone know what the cofg should be? Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted November 16, 2009 Share Posted November 16, 2009 A little bit further forward than you had it by the sounds of things Quote Link to comment Share on other sites More sharing options...
Alex Leigh Posted November 16, 2009 Share Posted November 16, 2009 That proved to be the case. I've decided it's like flying a jack russell. Properly bonkers. Quote Link to comment Share on other sites More sharing options...
Simon King Posted December 6, 2009 Share Posted December 6, 2009 Just received my Weasel from Dreamflight- impressive packaging and product. The fittings are all quality items. The glider was simplicity itself to build- the most difficult part being the cutting to size of the ailerons, the most time-consuming being the decoration- you simply can't leave it as plain old white EPP foam now can you? I covered mine- on the advice of Michael Richter- with coloured packing tape- I bought it from Staples at about 3 quid a roll. Just lay in strips slightly overlapping and for the edges cut little snips every 5mm or so and overlap and that will deal with the compound curves. I bought the power kit from Dreamflight for $50 and that included an NiMH battery, switch and two metal geared servos- all with shortened leads to exactly match the model- a great touch. Remember that space is a premium here and everything fits perfectly. If you want to make modifications, you will have to take a knife to that EPP! Mine is fitted with a Spektrum 6110e receiver and it all fits perfectly- only job I have to do is paint the inside of the plastic skid cover but it will have to wait until I get some spray paint. It is ready for flying now so will report back when it has flown- it balances perfectly with some 20 eurocent coins in the battery bay. Quote Link to comment Share on other sites More sharing options...
Simon King Posted December 6, 2009 Share Posted December 6, 2009 "Anyone know what the cofg should be?" There are little indentations under the wing- near the wing root which are the C of G locator marks. They recommend putting two pencil tips in these indications and balancing it that way. Using your fingertips is not accurate enough. The recomendation is for a slightly forward C of G for beginners, i.e. the Evo tilts slightly forward when balanced on the C of G markers. Quote Link to comment Share on other sites More sharing options...
Martyn Johnston Posted January 1, 2010 Share Posted January 1, 2010 Note: once you've covered it, or added fibre-glass reinforcing tape to the wing/fuselage join, as I did, you won't be able to see these indentations. First flight was chaotic, until I sellotaped a small stone to the front. Weighed the stone (10g) when I got home and replaced it with a bit of lead. Next flight ought to be better. Quote Link to comment Share on other sites More sharing options...
Grasshopper Posted March 15, 2010 Share Posted March 15, 2010 Yes, EVO CofG is marked in the foam by a couple of indentations and I built a jig from scraps of Depron with some long M4 bolts, hot glued to the base. I balanced it exactly level and then added a couple of grammes of lead so it was just nose down. The first flight was pretty scary but perfect in balance terms and I have not changed the CofG since. I suspect that if you balance with the old two fingers method then there could be tears though! Why scary - well It is a complete change from my normal slopers - Easy Glider and Star and also Elan (Cambrian Models). Twitchy and fast and requires 99% concentration for me at any rate. I use a cliff site over the sea here in Brittany with 8 to 10 knot winds at the moment. All up weight is 349g (OK 12.3oz then) and it it handles very well. I have 60% rates (from factory specified) on all the time which is controllable but after yesterday have dropped the aileron to 50% as near the 'land' where there is turbulence it is too easy to get caught out and flick into the bushes as happened yesterday. No sweat, brushed off the leaves , relaunched and that was that. This is a great 'plane and I love it ! Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted March 12, 2011 Share Posted March 12, 2011 Broke the plastic belly pan on mine yesterday - darn rocks I'm told that you can get better quality fibreglass versions on fleabay but cant find any. Anyone help? Quote Link to comment Share on other sites More sharing options...
r6dan Posted March 12, 2011 Share Posted March 12, 2011 I saw them last week as I was watching a weasel( that went for far too much), will have a look for them too. Quote Link to comment Share on other sites More sharing options...
r6dan Posted March 12, 2011 Share Posted March 12, 2011 The Weasel parts are no-where to be seen on EBay anymore..... Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted March 12, 2011 Share Posted March 12, 2011 I know.... Quote Link to comment Share on other sites More sharing options...
RGPuk Posted March 12, 2011 Share Posted March 12, 2011 For info, the Fleabay seller is/was sjbro1971 - I got a belly cowl set from him last week - a good, tough item, whose slight extra weight mitigates some nose lead anyway. Maybe a note to him through channels would illicit if he's getting more to list. Ro. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted March 12, 2011 Share Posted March 12, 2011 Cheers, I have emailed him If not, then I will get a couple of the original plastic ones from T9 and maybe glass one of them. Quote Link to comment Share on other sites More sharing options...
Matthew Lloyd Posted March 15, 2011 Share Posted March 15, 2011 I had a spare with my Wevo Tim Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted March 15, 2011 Share Posted March 15, 2011 to you then Mr Lloyd I happened to be flying with Ron Broughton ( SuperRonik Models ) at the weekend up the Orme, and as we discussed this amongst the usual tea break chatter - it turns out that its his son Stephen who is doing these on fleabay ( sjbro1971) - what a coincidence eh! I have spoken with Steve, and he has some white ones, and expects to have the black version back in stock over the next week or two. Meanwhile, being the impatient thing hat i am, I have just received this morning, two original versions from T9. I may just glass one of them. Quote Link to comment Share on other sites More sharing options...
