Alan Posted April 30, 2009 Share Posted April 30, 2009 Hi all Just purched a T6EX this is my first experience with radio gear when i pluged in my servos i found that CH2 is the throttle and CH3 is the Elevator going by the book and even the text on the front of the TX these are mixed up?? How would you go about setting these to the proper channels. Thanks Alan Quote Link to comment Share on other sites More sharing options...
Bruce Richards Posted April 30, 2009 Share Posted April 30, 2009 Sounds like you may have a mode 1 Tx when you were expecting a mode 2 or via versa. To check my understanding are you saying "when you move the left stck up and down the channel 2 is operated and channel 3 for the right stick"? Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted April 30, 2009 Share Posted April 30, 2009 if it's anything like the FF6 there will be a parameter for mode. This is what tells it whether to put the left/right hand stick to channel 2/3. Quote Link to comment Share on other sites More sharing options...
simon barr Posted April 30, 2009 Share Posted April 30, 2009 There are 4 modes in the 6ex. To change them, hold both mode buttons down before switching on, then switch on whilst still pushing the buttons. A single number should appear on the screen, either 1,2,3 or4. Simply use the up/down button to change to the mode required, usually 2, then turn off the tx. When you turn on again, all should be well. Edited By simon barr on 30/04/2009 18:31:23 Edited By simon barr on 30/04/2009 18:33:26 Quote Link to comment Share on other sites More sharing options...
Alan Posted April 30, 2009 Author Share Posted April 30, 2009 Thanks all for your help. As eveybody said the Tx was set to Mode1 i have now changed to it to Mode 2 and everything is working fine now. Jus have to learn how to fly the plane. Quote Link to comment Share on other sites More sharing options...
