James Ellis Posted September 17, 2009 Share Posted September 17, 2009 As the description says, why does there need to be a switch on the FF8 module to make it work with 7 or 8 channel Futaba recievers? Does anyone know, or have a link to an explaination? From the manual it looked like it was the same for the 10C transmitter, however this will operate the 6,7 and 8 channel receivers, not just the 7 and 8 channel like the FF8. The FF7 module only operates the 7 channel receiver as far as i can remember. Are other manufacturer systems the same? Spectrum, etc. Quote Link to comment Share on other sites More sharing options...
John Privett Posted September 17, 2009 Share Posted September 17, 2009 Futaba (USA) have a compatibility chart on their website showing what can be used with what. In summary, the R606FS receiver (which was discontinued some time ago) can't be used with the TM-7 or TM-8 modules. Also the 6 and 7 channel txs and modules can't work with the 8 and 14 channel rxs. Or so the chart says! Quote Link to comment Share on other sites More sharing options...
James Ellis Posted September 17, 2009 Author Share Posted September 17, 2009 Yes, that chart is very useful, thanks. In fact it shows a 4 channel receiver that works in 7 channel mode. I see that on the purpose built 2.4GHz transmitters, instead of a manual switch, compatibility is via a screen selection. I would still like to know why this is and also if other systems need to switch between 1-7 and 8-14 channel mode. Quote Link to comment Share on other sites More sharing options...
andy watson Posted September 17, 2009 Share Posted September 17, 2009 The 10 has the same "feature" On the plus side it does stop me flying my planes with the 14 channel rx in when I am set to a 7 channel rx. But apart from that minor fringe "benefit" I don't know why it does it either! Quote Link to comment Share on other sites More sharing options...
Ultymate Posted September 17, 2009 Share Posted September 17, 2009 I think on the smaller R/X's it's on 1024 and on the larger ones 8-14 it's 2048 resolution Edited By Ultymate on 17/09/2009 15:49:22 Quote Link to comment Share on other sites More sharing options...
