Nick Holmes 2 Posted September 27, 2009 Share Posted September 27, 2009 Hi have a couple of the standard Futaba battery chargers that came with my radio sets, have recently purchased some Enloop Nimh batteries to replace the TX and RX battery can I still use the standard chargers or do I need to buy a new charger? many Thanks Nick Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted September 27, 2009 Share Posted September 27, 2009 Yes.... just adjust the time of charge to suit the capacity. Quote Link to comment Share on other sites More sharing options...
ntsmith Posted November 5, 2009 Share Posted November 5, 2009 The charge curve for those cells would be slightly different but it shouldnt be a problem. As said before. Just adjust the time accordingly. Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted November 5, 2009 Share Posted November 5, 2009 May I suggest getting the newish "Fusion" charger? £9.99 & it detects when to stop charging Rx packs. I use one for my Vapex Instants & there's an adaptor for different polarity Tx packs .Charging rate is 750 mA delta peak for Rx's & 150 mA constant for Tx packs Myron Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted November 5, 2009 Share Posted November 5, 2009 PS What I meant was an adaptor for different polarity plugs for Tx's Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted November 5, 2009 Share Posted November 5, 2009 Timbo It's not easy to judge just how long to charge nimh's is it .As you've mentioned -there's very little voltage difference between charged & nearly discharged .I try my best to work it out theoretically but never quite sure whether it's too long or not quite long enough .With the charger I've mentioned ,this applies to the Tx only of course .They must have their reasons for not having a delta peak cut off (Apart from price ?).Is it because it's not that critical ? Quote Link to comment Share on other sites More sharing options...
Bruce Richards Posted November 5, 2009 Share Posted November 5, 2009 If you are charging at a low rate C/10 or less then it is not necessary to have delta peak cut off (and it would not work at such a low charge rate). It would not matter if you let the pack charging for twice as long as it needs. All the additional charging would just be converted to heat and at low rate this is a small amount of heat.Edited By Bruce Richards - Moderator on 05/11/2009 14:16:42 Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted November 5, 2009 Share Posted November 5, 2009 Bruce Thanks for that ! Quote Link to comment Share on other sites More sharing options...
Erfolg Posted November 5, 2009 Share Posted November 5, 2009 The same question has been bothering me. I presently principally use Futaba 6 Ex...? transmitters, one I re-batteried with a higher capacity Nicad. Unfortunately, no, stupidly, I did not get round to doing the same with the second, before legislation made the sale of Nicads illegal. So will have to replace this with a higher capacity Nimh. Why does it come with such a low capacity battery, as a battery with greater capacity costs so little more. To date I have not done this due to indecision and uncertainty, regarding charging. Erfolg Quote Link to comment Share on other sites More sharing options...
Bruce Richards Posted November 5, 2009 Share Posted November 5, 2009 I scrapped my standard wall wart charger a couple of years ago and bought an all singing all dancing charger where you can set the charge rate and detect the delta peak. I can charge just about any pack (accept for very large lipos) in an hour or less. If you are going to buy new high C batteries you relly need a charger that can charge at higher rates. It need not cost a fortune £30 or so should get you a reasonable charger you can use fron 12V supply or car battery.Edited By Bruce Richards - Moderator on 05/11/2009 16:23:56 Quote Link to comment Share on other sites More sharing options...
