Mark Jones Posted July 12, 2007 Share Posted July 12, 2007 Which EDF jets are any good, thinking of buying one.Would love some feed back on some tried and tested ones. Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted July 12, 2007 Share Posted July 12, 2007 The Eze-fan is great if you're happy building your own Mark. David. Quote Link to comment Share on other sites More sharing options...
Mark Jones Posted July 12, 2007 Author Share Posted July 12, 2007 Thanks David i have thought about that one it does look good! Mark Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted July 12, 2007 Share Posted July 12, 2007 Very easy to build too. The J.Perkins Tigershark flies well but being depron it's not very robust. We've yet to fly the Multiplex Twister.David. Quote Link to comment Share on other sites More sharing options...
scott cuppello Posted July 12, 2007 Share Posted July 12, 2007 Do not reccomend Kyosho Illusion, just far too much money for a tiny plane that's only attribute is that it's fast [isn't that the point of EDF anyway?].Can reccomend Alpha Sabre, one of the guys at the club got one last week, and everybody loves it, and that's on stock fan and 3s Lipo, so nowt fancy. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted July 12, 2007 Share Posted July 12, 2007 Its actually ALFA not ALPHA ( different company )I too have this plane, but would suggest that it is not for beginners. OK as first EDF, but should be experienced pilot generally, b4 trying this one. It gets real small quick, it slows a lot in the turns ( just like most jets ) but otherwise its a beauty. Quote Link to comment Share on other sites More sharing options...
YakMad Posted July 13, 2007 Share Posted July 13, 2007 I have the Multiplex Twister it's easy and fast to build and flies ok with the stock motor and fan and would suit someone starting out in EDF but does not really have the performance of something like the Tigershark, which is disappointing from my point of view. Quote Link to comment Share on other sites More sharing options...
YakMad Posted July 13, 2007 Share Posted July 13, 2007 Jetsome, Mine hand launched fine, I was using 20 c discharge 3s Hyperion cells in it will climb steeply from launch but I have managed to burn out the bearing in the motor, I do like full throttle. I'am going to replace it with a Venom Heli motor, it certainly is impressive for the money as I have the Alfa jets as well which fly well but have nowhere near the performance of the Tigershark, I may just have buy a second one if replacing the motor proves too difficult. Quote Link to comment Share on other sites More sharing options...
YakMad Posted July 13, 2007 Share Posted July 13, 2007 I think I may just have gotten a faulty motor, the Venom is the motor that CML are recommending for the Alfa jets it has 4900 revs per volt so should be similar to the motor supplied originally with the Tigershark, I am hoping that it will be more efficent as the original motor pulled over 22 amps at full power. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted July 14, 2007 Share Posted July 14, 2007 CML supplied me with an AON 4900 for my alfa sabre, and it has now completed around 60+ successful flights Quote Link to comment Share on other sites More sharing options...
YakMad Posted July 17, 2007 Share Posted July 17, 2007 Has anyone seen the new Phase 3 F-16 (in the flesh) complete with fan,brushless motor and esc, I wonder how the performance would compare with the Tigershark, (and it's cheaper too). Quote Link to comment Share on other sites More sharing options...
scott cuppello Posted July 17, 2007 Share Posted July 17, 2007 I'll be able to tell you in about a week Roy, have one coming with a 4s set up. Quote Link to comment Share on other sites More sharing options...
YakMad Posted July 17, 2007 Share Posted July 17, 2007 Scott, Thanks, hope I can hold out that long, very nearly ordered it to-day. Quote Link to comment Share on other sites More sharing options...
YakMad Posted July 18, 2007 Share Posted July 18, 2007 The new Venom motor arrived for my Tigershark, for info, it's a Venom v20L, 4980 kv, recommended for up to 60mm fans, now all I need is the hands of a surgeon to swap the motor's. Quote Link to comment Share on other sites More sharing options...
scott cuppello Posted July 29, 2007 Share Posted July 29, 2007 F16 maiden flight today.....oh wow, I'd seen somebody in the States with the same set up as mine, they reckoned 100mph....I was,hmmmmmm, whatever...well, don't know how fast it is, but it's the fastest thing anybody has seen at the club barring a turbine.Not only that, but amazingly, it's a pussycat, half throttle, and it will still go vertical from level flight, but was flown in this horrendous wind [must be 15mph+]....did a pass at around 5ft [not me, somebody better than me!], full bore....no rocking wings, totally rock steady in conditions that were blowing my Ripmax Spit around quite badly....like I said, this is on a 4s [14.8v] set up, but I reckon the 3s one would be good fun. Quote Link to comment Share on other sites More sharing options...
YakMad Posted July 29, 2007 Share Posted July 29, 2007 Scott, Thanks for the update. Quote Link to comment Share on other sites More sharing options...
jimbo Posted September 17, 2007 Share Posted September 17, 2007 the f 16 sounds great, any info on the distributer Quote Link to comment Share on other sites More sharing options...
scott cuppello Posted September 18, 2007 Share Posted September 18, 2007 There are half a dozen kit's at the mo that are basically all the same, barring the name on the box and the power set up. "Our's" [can't go into shamless plugging here, although you could pm me for a website address?] is the same airframe as the others, comes in plain white foam, Mega 55 fan, with motor options for 3s or 4s. I painted our's in desert storm type colours, mainly because of painting foam! Used magnolia matt emulsion for all surfaces for base colour and to "seal" foam, then Plasticoat horrible brown, lightly blown for camouflage look [er, just don't land in a barley field like somebody did!].....looked great, much better than all grey/white for such a small/fast model! Quote Link to comment Share on other sites More sharing options...
jimbo Posted September 18, 2007 Share Posted September 18, 2007 Thank's scot love to pm but havent a clue how to do it I will use your info and trawl through the addsin the mag. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted September 18, 2007 Share Posted September 18, 2007 Just click the envelope icon in his red / grey banner alongside his name. Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted August 18, 2008 Share Posted August 18, 2008 Check out the world models unijet, based on the fan trainer, comes artf complete with fan and brushless for just over £100. This is my first edf and been flying it all summer can't sing its praises loud enough, fast, slow in any weather simply brilliant. Got mine from Steve Webb Models. Photo in gallery. Quote Link to comment Share on other sites More sharing options...
winchweight Posted August 19, 2008 Share Posted August 19, 2008 Jimbo,The Phase 3 F16 is distributed by Ripmax, but if you're stuck my LHS does mail order[email protected]Speak to Derrick or MartinPhase3 F16 Build Blog (with video) Quote Link to comment Share on other sites More sharing options...
John Whoriskey Posted August 19, 2008 Share Posted August 19, 2008 the fantom is a good first edf goes together quick stedy at fast and slow speed just brill Quote Link to comment Share on other sites More sharing options...
