Hamish Posted November 19, 2009 Share Posted November 19, 2009 New to electrics and got myself a GT Power V5 Balance Charger. When charging there is displayed a "Charged Capacity". What is this and how is it interpreted? Quote Link to comment Share on other sites More sharing options...
Olly P Posted November 19, 2009 Share Posted November 19, 2009 Hamish, this is similar to my charger and the charged capacity is how much has been put back into the battery, and gives you an idea of how much you used up last use. not much use imho, as the rest voltage will give you the approx % of charge remaining. Quote Link to comment Share on other sites More sharing options...
Robert Bromwich Posted November 19, 2009 Share Posted November 19, 2009 Hi Hamish Charged capacity is the amount on ampere (ma) that the charger has put into your battery have a look in your manual tells you all you need to know about programing in there if you havent got it then here it is GT V5 charger Manual robEdited By Robert Bromwich on 19/11/2009 20:04:36 Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted November 19, 2009 Share Posted November 19, 2009 hello hamish-- your in Timbo territory..he will give you an explanation...right down to the last fullstop. ken anderson.............. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted November 19, 2009 Share Posted November 19, 2009 Nowt to add to what the lads have already said - except I dont agree that its not useful info....it can,if monitored and recorded over time, show the early signs of battery failure as cells start accepting less and less back in.Edited By Timbo - Administrator on 19/11/2009 20:11:40 Quote Link to comment Share on other sites More sharing options...
Hamish Posted November 19, 2009 Author Share Posted November 19, 2009 Thanks for info. I would imagine if you had a totally flat battery you can measure how much you have put in to bring it up to full charge. Monitoring the duration of flights and then recording how much is put back in would be some form of rough measure, however the nature of the flight and conditions would have an effect. Not sure I want to go into this depth but at least I now no what this figure is which was not explained in the manual. Thanks again all Quote Link to comment Share on other sites More sharing options...
Former Member Posted November 21, 2009 Share Posted November 21, 2009 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
flytilbroke Posted November 21, 2009 Share Posted November 21, 2009 Lipo's if allowed to go "totally flat" are landfill. new ones required. I think you have been given enough info to keep you going for short time tho'. Likely you will want more. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted November 22, 2009 Share Posted November 22, 2009 Charged capacity is quite useful, although voltage will let you know approx how much is left in the battery this can be used to determine the useful flight time. I usually adjust my Tx timer over the first few flights to get around 80% of the battery capacity. Measuring the charge put back in lets me work up to this quicker. Quote Link to comment Share on other sites More sharing options...
