Stephen Grigg Posted December 29, 2010 Author Share Posted December 29, 2010 Had a bit of a search about and found a BRC Hobbies 20 amp Speed controlle r.Tried that still the same.Motor starts to turns you apply throttle then makes funny noises and stops dead,like if the timing is out.Tried a program card, still the same.Then I found another motor with a speed controller. soldered to it.The speed controller was very small and had damaged plug wiring.Snipped the motor off .Set myself up to solder gold plate bullets onto the motor.First soldering iron wouldnt warm up.Found a second one and I"m off.First connector soldered.Onto the 2nd connector and the iron literally blows up with a big bang(yet to investigate.) Dimantle the first one and a wire has come off but it all sealed so cant get at it.Find a 3rd soldering iron(didnt know Id got 3) This one is a bit slow.So I warm the bullets on the gas hobb ans complete the soldering.Connect it all together seems OK,check with the other motor less prop ,that seems ok as well.Now I cannot find a prop to fit the second motor,because the first one has a threaded prop shaft,the second has a prop adaptor.Finally I just drill the prop,fit it on and it works fine.So its at last ready for a maiden flight. Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted December 30, 2010 Author Share Posted December 30, 2010 took th Texan for its maiden flight but the synchronisation between myself and my friend went way out ,and we broke the only prop I had,waiting for a new prop. Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted December 31, 2010 Author Share Posted December 31, 2010 Searched all over but cannot find a prop anywhere,I know I have one somewhere as well. Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted January 5, 2011 Author Share Posted January 5, 2011 Props arrived today,so maiden soon Quote Link to comment Share on other sites More sharing options...
Nick Farrow Posted January 6, 2011 Share Posted January 6, 2011 Hi Steven, I got one of these for Christms and am partway through building it, waiting for esc/motor/radio to arrive. I'm going to fly this with a 10x6 on it as that seems to work well with the p40 I have with a 250watt motor. I'll postion the motor from the firewall when I've go everything else on board. What cog did you go for and whats the all up weight? Also interested in what paint you used! Thanks nick Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted January 6, 2011 Author Share Posted January 6, 2011 Hi Nick I confess I never weigh my models.The current yellow model came painted.Be careful with the choice of paint,I wrecked my first GWS model by using the wrong stuff.Look up another recent thread on painting foamies.I set mine at the recommended C of G,if you need the measurement let me know and Ill look it up Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted January 7, 2011 Author Share Posted January 7, 2011 The thread just below Nick Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted January 9, 2011 Author Share Posted January 9, 2011 At last the yellow Texan had its maiden flight,took a bit of trimming but was great to fly once balanced.It was good to get it in the air at last. Quote Link to comment Share on other sites More sharing options...
Kelly Posted January 10, 2011 Share Posted January 10, 2011 Good one Stephen Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted January 10, 2011 Author Share Posted January 10, 2011 Yes ,took me a while to get there Kelvin. Quote Link to comment Share on other sites More sharing options...
Erfolg Posted January 20, 2011 Share Posted January 20, 2011 Am I the only one with this issue? When I have the cowl in position, I cannot get the battery hatch off. When trying to remove it, it fowls the canopy.I am considering effectively shortening the hatch so it finishes at the cowl,. The question then is will it be large enough to get the lipo in and out.I have bought a Zippy 2200 for it, and I am awaiting its arrival. I should have bought two as they were only £9. The Zippy I have is a very tight fit. indeed there will be a need for the body to be relieved.My CG is a little far forward of the 95mm.In principal it is ready, that is after the obligatory final photo. The above is the model yesterday before final painting and gear going in. Quote Link to comment Share on other sites More sharing options...
Nick Farrow Posted January 20, 2011 Share Posted January 20, 2011 HI, I assumed it was a secondary means of ensuring the 'leading edge' of the hatch does not get airbourne - I saw that as good design nick Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted January 20, 2011 Author Share Posted January 20, 2011 Ive cut some of the cowl off ,Erfolg.I couldnt quit get a 2200 in so I have a 1600 that just fits.Fitting the battery cover is a bit fiddly but ok. Quote Link to comment Share on other sites More sharing options...
Erfolg Posted January 31, 2011 Share Posted January 31, 2011 I have completed the model now with all gubbins installed. The adhesion of Acrylic paint onto the cowl is not great. The wight has come out at 683g or 24oz, which is over the quoted GWS figure of 22oz. It unfortunately needed 20g of weight in the tail, which you may be able to see in the photo. I cast a little ingot and epoxied in place. I will do a Watts and rev check tomorrow with a little luck and time. Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted January 31, 2011 Author Share Posted January 31, 2011 I didnt need to add any weight to mine Erfolg and 20 grams sounds a lot doesnt it Quote Link to comment Share on other sites More sharing options...
Erfolg Posted January 31, 2011 Share Posted January 31, 2011 It is almost certainly the combination of the motor and lipo, An Emax 215 and a Zippy (i think, just got it) at 2200mah. "0 grams is about 3/4 oz , over approx 2 ft^2, in the region of 3/8 oz ft-^2, do not think that will be noticed, maybe the 14oz ft-^2 will be. What weight was/is yours? Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted January 31, 2011 Author Share Posted January 31, 2011 I dont bother weighing mine,Im using a 1600mah Quote Link to comment Share on other sites More sharing options...
