David Ashby - Moderator Posted May 20, 2010 Share Posted May 20, 2010 They're brought into the UK by CML Distribution Richard (see flight hub advert>>>>>>>> So they'll have them in, in due course. Quote Link to comment Share on other sites More sharing options...
ericrw Posted June 26, 2010 Author Share Posted June 26, 2010 On connecting the retract servos on my FMS Mustang, I found that one of them was a dud! As I will now be having to buy another set of two, I would like to know of, not too expensive, what to buy for this model? I find that sites such as Servo Shop, a bit confusing, with my lack of knowledge, as to what specification I should be considering for my retracts. Any advice/suggestions appreciated. Thanks Eric. Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted June 27, 2010 Share Posted June 27, 2010 Eric, you too eh? I fitted metal gear micros when my retract servos died. Just the parkzone ones I had to hand but anything similar should be fine. Quote Link to comment Share on other sites More sharing options...
ericrw Posted June 27, 2010 Author Share Posted June 27, 2010 Thanks David, Unfortunately, with the many variations of servo's available, I need guidence in choosing the correct servo. For eg, dimensions I can work out but torque or speed is another matter. When I go to "Servo Shop" , I just see a mass of different numbers and types of servo's and not being technically minded, it just throws me. If you can help further it would be appreciated !! Eric. Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted June 28, 2010 Share Posted June 28, 2010 Hi Eric I used little Parkzone DSV 130Ms but I can't see them at Webbies so try Hitec 81 MG- they seem to have then at £9 each. Give me an hour and I'll go and check the 81 size in the model...back soon. Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted June 28, 2010 Share Posted June 28, 2010 Hi Eric, yup the 81MGs will be fine Quote Link to comment Share on other sites More sharing options...
ericrw Posted June 28, 2010 Author Share Posted June 28, 2010 Thanks! I appreciate your help!! Will now order the 81's. Eric. Quote Link to comment Share on other sites More sharing options...
Tony Read 2 Posted June 29, 2010 Share Posted June 29, 2010 Anyone got sloppy retracts? Mine lock up but there is quite a bit of slop in the mechanism allowing the retracts to droop.Edited By Tony Read 2 on 29/06/2010 14:00:25 Quote Link to comment Share on other sites More sharing options...
gary farnworth Posted July 30, 2010 Share Posted July 30, 2010 Hello All,Just jointed this forum and noticed this thread, as I have just bought the P51 in yellow nosecone, my brother has the red one as your photo. I have not flown mine yet, but there are several differences,1. The retracts on my model work on a servo worm gear and lock up & down with no play and are a very well engineered piece of kit. My brother has the 'old' type worked by a servo and have a lot of play when down. he is looking at buying a set of the worm gear from CML.2. The motor on mine has a built in lock for the plate for the spinner, my brothers does not and is a pain to lock up. I will be flying mine on wednesday, and I will put it through its paces, and report on here if it falls to bits in flight. Quote Link to comment Share on other sites More sharing options...
ericrw Posted July 30, 2010 Author Share Posted July 30, 2010 I have now fitted Hitec-82 MG servos as per the modification suggested by CML, see my thread dated June 6th, under FMS Mustang. There is an improvement and the u/c stays locked in the down position but I still get a bit of droop even though I put in 150% travel adjust on my transmitter. Is it possible to get a flush fitting ??? Eric. Quote Link to comment Share on other sites More sharing options...
Tony Read 2 Posted August 4, 2010 Share Posted August 4, 2010 Eric, I resorted to gluing a magnet into the wheel well and one to the under cart leg to hold up flush. Works well, but you need to check that your servos can break the bond to get the u/c down. I had to play around for a bit to get the attraction just right. If you have an old brushless motor that you have destroyed (like me!) you have a plentiful supply of magnets. Or you might be able to shim the inboard retract fixings to angle the retracted leg up further into the well. Quote Link to comment Share on other sites More sharing options...
Tony Read 2 Posted August 9, 2010 Share Posted August 9, 2010 How do most people transport their Mustangs in their car - take one or more wings off? This does seem a bit fiddly so I was thinking of making the wing one piece, held on with the four fixing screws, plus matbe a stong magnet. I would fly it 'scale' so not too much negative g would be involved. Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted August 9, 2010 Share Posted August 9, 2010 I manage to get mine in the car in one piece Tony (std size saloon). Agree it's too fiddly to take apart. Quote Link to comment Share on other sites More sharing options...
ericrw Posted February 25, 2011 Author Share Posted February 25, 2011 Well at long last I maiden my Mustang, yesterday. She flew extemely well,according to fellow flyers on the day but it left me with a "dry mouth" just as I used to get when I first began to fly r/c. No doubt due, because it was my first time to control a low wing model. Unfortunately, on my third landing the grass tore the retractable gear away from it's housing. Easily to done as it is a foam model. Quote Link to comment Share on other sites More sharing options...
paul@scc Posted February 25, 2011 Share Posted February 25, 2011 Congrats on your maiden Eric. Here are the pics of the Mustang. Edited By Tim Mackey - Administrator on 25/02/2011 17:46:10 Quote Link to comment Share on other sites More sharing options...
ericrw Posted February 25, 2011 Author Share Posted February 25, 2011 That is a lot better! Did your mate reinforce the foam for the E.flite landing gear and if so how ?? Eric. Quote Link to comment Share on other sites More sharing options...
paul@scc Posted February 25, 2011 Share Posted February 25, 2011 Knowing him, he probably has. I will ask next time I see him. I must say the Eflite retracts are great. Not sure what's happening, but when I click on anything in the tool bar at the top of the reply post my screen turns light blue and I get a red circle with a line through it. Whats that all about.. ?? Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted February 25, 2011 Share Posted February 25, 2011 Try logging out /in and a re-boot. Quote Link to comment Share on other sites More sharing options...
paul@scc Posted February 25, 2011 Share Posted February 25, 2011 OK. I have worked it out. You have to scroll back up to the top of the page to find the window. Very strange. Quote Link to comment Share on other sites More sharing options...
Tony Read 2 Posted April 20, 2011 Share Posted April 20, 2011 Anyone know when the 'blue nose' version 6 will be out? It has the electric u/cart tilted forwards much more and a fully retracting tail wheel as standard. Quote Link to comment Share on other sites More sharing options...
paul@scc Posted April 20, 2011 Share Posted April 20, 2011 My mate flew his Mustang recently. I had a go on the sticks and I must say it was a joy to fly. Lost the tail wheel in flight. Edited By paul@scc on 20/04/2011 15:32:44 Quote Link to comment Share on other sites More sharing options...
matthew carr Posted May 20, 2011 Share Posted May 20, 2011 i dont suppose anyone knows the best c of g for the large fms mustang as i dont really trust the manual . thanks Matty Quote Link to comment Share on other sites More sharing options...
Tony Read 2 Posted May 23, 2011 Share Posted May 23, 2011 There are two round indents on top of the wing (covered by decals if I remember correctly) that is where I believe the COG should be. Quote Link to comment Share on other sites More sharing options...
Tony Read Posted April 9, 2012 Share Posted April 9, 2012 Dusted down the Mustang today to prep it for flying. I've had it a year but its still unflown due to lack of space in car, until now. Anyway, connected battery and controls worked fine. Bliped the throttle and the motor made a graunching noise with the prop flicking rapidly one way and then the other. This was followed by smoke from the ESC. Pulled the battery PDQ and cannot see any damage. The motor turns freely by hand, what gives? Feel like I don't want to trust motor or ESC now, even though they are unused. Quote Link to comment Share on other sites More sharing options...
stuey Posted April 9, 2012 Share Posted April 9, 2012 Sounds like the controller didnt pick up the motor timing and got the hump. I understand why you might not want to try a different controller, but if you do it really quickly and stop instantly if it doesnt spin properly you can find out! I have read that quite a few people have had issues with these controllers on another forum. I have always done well (touch wood!) with Hobbywing controllers. Quote Link to comment Share on other sites More sharing options...
