jonathan wood 1 Posted May 26, 2010 Share Posted May 26, 2010 has anyone fitted a 52 four stroke to the pulse xt 40? i,m considering doing so but am concerned it might be a little underpowered. Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted May 26, 2010 Share Posted May 26, 2010 I saw one advertised with an sc 52 4str,I flew mine first with anThunder Tiger 46 Pro,to powerfull,changes to an OS46 LA very good,now fly with an OS 46 FX which is also very good.Have considered putting an SC 52 in but happy with how it is.I believe the 52 4str would give you more than enough power,Good luck Quote Link to comment Share on other sites More sharing options...
jonathan wood 1 Posted May 26, 2010 Author Share Posted May 26, 2010 thanks stephen. i have an old os 46 max which could go in but i fancied a 4 st and i have a kyosho 52 which has been a good engine. i intend to buy the pulse this week to replace my recently totalled super air. all the reports on the pulse seem very good indeed although it is of course considerably more expensive... Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted May 27, 2010 Share Posted May 27, 2010 Yes it is but the coverineels are better quality.My Sg for a start is far superior and things like whuper Air didnt get a fair comparison but I love my Pulsed when my first one suffered a radio glitch I did go out and buy a second.This one suffrered a midair with a novice(his model,nott him) but I was able to land mine safely.The wing was badly damaged and the u/c mount suffered internal damage.The wing repaired fine but I havent managedto get the strength back into the u/c mount as yet Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted May 27, 2010 Share Posted May 27, 2010 I have a Pulse XT40 with a Thunder Tiger GP42 up front. Plenty od power in that configuration - will go vertical beyond the extent that I'm have to let it! So, I guess it will fly OK with a 52 four stroke - but might be a bit limited. The GP42 is spec'ed to put out just 1.1HP. What's the power output of the 52 4-stroke? If its close to this - it'll be fine BEB Quote Link to comment Share on other sites More sharing options...
jonathan wood 1 Posted May 28, 2010 Author Share Posted May 28, 2010 thanks, having now found my subscriber number i,ve been able to access the rmce review model which as luck would have it as fitted out with an sc 52. the only thing i need now is the plane itself as noone seems to have one in stock! Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted May 28, 2010 Share Posted May 28, 2010 Have you tried Galaxy,theyve always had one when Ive had the need Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted May 28, 2010 Share Posted May 28, 2010 Filing that try Steve Webb's (that's were I got mine). BEB Quote Link to comment Share on other sites More sharing options...
Simon B Posted May 28, 2010 Share Posted May 28, 2010 I bought the review model! I sold the SC52 though and electrified the model... Quote Link to comment Share on other sites More sharing options...
jonathan wood 1 Posted May 28, 2010 Author Share Posted May 28, 2010 thanks for the suggestions i managed to find one at totem hobbies.should be with me by tuesday. that will give me time to strip ond give it the once overut the kyosho 52 from my kyosho pitts and give it the once over. does anyone see any advantage to glueing the wing together and the tail feathers or are the bolted joints ok? Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted May 28, 2010 Share Posted May 28, 2010 I have just bolted mine - particularly in the case of the tailplane I think this is possibly better. If you glue it you will have to remove the covering and you may damage the tailplane - scoring it - if you're not very careful. The bolts have so far prooved to be no problem. BEB Quote Link to comment Share on other sites More sharing options...
Hugh Coleman Posted May 28, 2010 Share Posted May 28, 2010 I have an OS 52 Surpass in my Pheonix Tiger 40 II (wiht an APC 12 x 6 Prop). Really, it's underpowered (but not as bad as it was with the 11 x 6). I'm looking at getting a Pulse 60 and putting an OS 55AX in it (as soon as the money for the horse I just sold starts coming through) and I'm told that that engine should give that model plenty of get up and go. Considering how light the Pulse 40 is, the 52 FS would probably be fine. Cheers, Hugh Quote Link to comment Share on other sites More sharing options...
Steve Houghton 1 Posted May 28, 2010 Share Posted May 28, 2010 I shall look forward with interest with how you get on with your choice of 4s as the Pulse XT40 is my plane of choice for next spring and i too wish to fit it with a 4s. I was thinking of the ASP70 but from what I've read here that may be to powerful. Steve Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted May 28, 2010 Share Posted May 28, 2010 Worth remembering that the ASP61 4 stroke is actually the same size as the ASP/SC 51 4 stroke (the extra capacity comes from a bigger bore) & might add that little bit of extra sparkle to the performance.....Edited By Steve Hargreaves on 28/05/2010 13:38:57 Quote Link to comment Share on other sites More sharing options...
jonathan wood 1 Posted May 31, 2010 Author Share Posted May 31, 2010 does anyone know the best way to seal the exhaust pipe unions on four stroke engies t prevent all that horrible baked on oil messing them up? Quote Link to comment Share on other sites More sharing options...
Shaun K Posted May 31, 2010 Share Posted May 31, 2010 Hi Jonathan, there's an old thread here that helped me out with the leaky pipes: http://www.modelflying.co.uk/forums/postings.asp?th=12593 Shaun. Quote Link to comment Share on other sites More sharing options...
jonathan wood 1 Posted June 22, 2010 Author Share Posted June 22, 2010 well i,ve finally completed my pulse 40 Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted June 22, 2010 Share Posted June 22, 2010 Now the enjoyment begins,when its first flight Jonathan Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted June 22, 2010 Share Posted June 22, 2010 And.... Don't leave us in suspense! BEB Quote Link to comment Share on other sites More sharing options...
jonathan wood 1 Posted June 22, 2010 Author Share Posted June 22, 2010 will do Quote Link to comment Share on other sites More sharing options...
jonathan wood 1 Posted June 22, 2010 Author Share Posted June 22, 2010 For all of those wishing to install an SC 52 FS engine in to pulse 40 here are my pedantic instructions: first of all reverse the throttle arm so it is vertical , install the engine and arrange the radius of the throttle arm to include the full range of openings, whilst avoiding coming up against either the firewall or the engine cylinder.Then take the stiffest wire you can get away with, and at approx 70mm from throttle end of wire make a 90 deg bend. Install the wire in its tube so thAT YOU CAN SEE HoW THINGS ARE GOING. Now make a second 90 deg bend approx 25mm from the first at right angles to the main wire. this shoud take the wire across the top of the engine mount but be low enough to clear the cowl when fitted. Make another 90 degree bend upwards approx 30mm from the last. This should line up the wire parallel with the throttle arm and the end can be inserted in to a connector on the throttle arm. Iue the outer hole and oneof those brass connectors wtih the spring steel disc on the back. There is enough movement in the wire to allow for the vertial change as the lever goes through its arc. You can make fine adjustments using EPA on the tx. Dead simple, flight tested, works well. Quote Link to comment Share on other sites More sharing options...
Peter Roberts Posted August 27, 2010 Share Posted August 27, 2010 For Steve Houghton, I built and flew a Pulse XT 40 only on electric and used flightpower 20C 4s 3700 lipos. These were OK it flew beautifully but I would have liked a bit more grunt. One friend started to use 5s another bought a newer 4s lipo with a 30C discharge - made a large difference. But a lovely plane. Peter Quote Link to comment Share on other sites More sharing options...
Peter Roberts Posted August 27, 2010 Share Posted August 27, 2010 By the way I also have a Pulse XT 60 - lovelyu plane but don't fly it on 5s use 6s instead. I bought some end of line Flightpower 6600 mah 6s2P and they give 18 to 20 min flights. I've also bought some Hobby City 6s 4900 which are good especially the 25C versions. I modified the tank bay by removing the throttle cable lug on one of the formers and building some above wing support - strong as houses! Still like the XT 40 best of the 2. I have a Pulse XT 25 with 4s - that's sparkling but difficult to add and remove the 4s battery. Quote Link to comment Share on other sites More sharing options...
Phil 9 Posted August 27, 2010 Share Posted August 27, 2010 Why do you like the 40 better? I just bought the 60 have I made an error? Quote Link to comment Share on other sites More sharing options...
Allan Bowker Posted August 27, 2010 Share Posted August 27, 2010 I have the 60 Phil and it flies like a dream, I wouldn't say you have made a mistake.Powered by a 6S 4200mAh Li-Po and an E-Flite Power 60 motor gives energetic 15 minute flights. Edited By Allan Bowker on 27/08/2010 00:27:01 Quote Link to comment Share on other sites More sharing options...
