James40 Posted September 17, 2011 Share Posted September 17, 2011 In standard form the motor and fan are quite noisy, not sure it it would break the noise limit though? Had a few flights on mine now, performance is fantastic on a 6S 4000mAh pack, such an easy plane to fly if you want to keep it sensible, in fact, close the throttle and it will almost float horizontally to the ground. With the gyro fitted in the nose it is possible to hold it in an almost hover, given a nice breeze and it would hover nicely! The gear hold up well on the electric retracts and landing is quite easy, she will come in at quite a high angle of attack using the throttle for a slow landing or at normal speeds and flare last minute but it needs more field to land like that. Quote Link to comment Share on other sites More sharing options...
Thomas Barwick Posted April 12, 2012 Share Posted April 12, 2012 How have the servos held up as have heard some dodgy things about them. In the process of adding green mfds and light up buttonds and a light up hud. ( and of cource replacing that pilot). Quote Link to comment Share on other sites More sharing options...
Thomas Barwick Posted May 6, 2012 Share Posted May 6, 2012 Finished the cockpit now going out this afternoon to give it a test flight. Quote Link to comment Share on other sites More sharing options...
James40 Posted June 2, 2012 Share Posted June 2, 2012 Looks really good Thomas, have you flow it in the evening yet or in low light? Quote Link to comment Share on other sites More sharing options...
Thomas Barwick Posted June 2, 2012 Share Posted June 2, 2012 no my grass is too long at the minute had 3 aborted take-offs,just doesnt pick up enough airspeed, now looking around for tarmac so i can finally get it airbourne. Quote Link to comment Share on other sites More sharing options...
James40 Posted June 2, 2012 Share Posted June 2, 2012 Some guys have fitted a longer nose leg to help launching off grass, that may be an option for you? Are you using the vectored thrust? Quote Link to comment Share on other sites More sharing options...
Thomas Barwick Posted June 2, 2012 Share Posted June 2, 2012 yeh i am using the vectored thrust. I think i just need a smoother surface, and good weather Quote Link to comment Share on other sites More sharing options...
James40 Posted June 2, 2012 Share Posted June 2, 2012 Hand launch is always an option on this one, it has more than enough static thrust and very easy to grip. Quote Link to comment Share on other sites More sharing options...
Thomas Barwick Posted June 2, 2012 Share Posted June 2, 2012 Yeh thats just dont want something to be majorly out of trim and it crash or get cuahgt out by the thrust vector as its my first tv jet :s Quote Link to comment Share on other sites More sharing options...
James40 Posted June 2, 2012 Share Posted June 2, 2012 Ah ok, I didn't realise this was the maiden! They do tend to stick to the ground on take off roll then leap into the sky! Have you read the huge thread on rc groups on this airframe, it tells you how to set the foreplanes up correctly etc to make takeoff easier. Edited By James40 on 02/06/2012 20:25:20 Quote Link to comment Share on other sites More sharing options...
Thomas Barwick Posted June 2, 2012 Share Posted June 2, 2012 the thread is long and i thought i had read something somewhere but i cant seem to find the post with he suggestion Quote Link to comment Share on other sites More sharing options...
James40 Posted June 3, 2012 Share Posted June 3, 2012 Well from memory, put a needle in the join line on the forward fuselage to the rear of the foreplanes and line up the trailing edge of the foreplanes with that needle. That should give the foreplanes a slight nose up attitude, if it doesn't then it may be the leading edge that was aligned with the pin, which ever way gives the nose up setting to the foreplanes. That setting was found to give a nicer take off and nicer flight characteristics. Quote Link to comment Share on other sites More sharing options...
