matt mason Posted August 27, 2010 Share Posted August 27, 2010 anyone used or are using XT60 connectors.? what they like...? cheers matt Edited By matt mason on 27/08/2010 20:25:32 Quote Link to comment Share on other sites More sharing options...
Ed Darter Posted September 2, 2010 Share Posted September 2, 2010 yep - have started to use them after buying some duff EC3s from GC. Seem very good actually, and apparently most of the US stuff will be sporting them going forward (so I'm told anyway). Certainly cheaper than EC3's and less hassle to put together. Quote Link to comment Share on other sites More sharing options...
Steve W-O Posted September 2, 2010 Share Posted September 2, 2010 I only use XT60 connectors, As you can see on the funcub, even if it doesn't need the extra capacity. There is less chance of hotspots on round connectors generally. Quote Link to comment Share on other sites More sharing options...
Redex Posted March 12, 2012 Share Posted March 12, 2012 Hi all, Just started to use XT60 connectors which seem really good. My XT60's seem very tight when connected which is good electrically, but makes them a bit awkward to disconnect in the confined space of a fuselage - just wondering if there is a tool/any tips to easily prise apart the connectors. Quote Link to comment Share on other sites More sharing options...
Mowerman Posted March 12, 2012 Share Posted March 12, 2012 I have changed from Deans to XT60, easier to solder and easier to grip when disconnecting. I now have a bag of surples/used Deans type connectors Quote Link to comment Share on other sites More sharing options...
Ben B Posted March 12, 2012 Share Posted March 12, 2012 I've been using them exclusively for the last couple of years. Very nice. And will certainly handle a lot more than 60 amps. I've run over 80 through mine without any warmth from the connector. Quote Link to comment Share on other sites More sharing options...
Tim C Posted March 12, 2012 Share Posted March 12, 2012 Using them almost exclusivly now Quote Link to comment Share on other sites More sharing options...
Turbycat Posted March 12, 2012 Share Posted March 12, 2012 I use em on my leccy stuff. Changed from deans a couple of years ago. Easier to use all round. Andy Quote Link to comment Share on other sites More sharing options...
Seamus O'Leprosy Posted March 12, 2012 Share Posted March 12, 2012 I made up some Deans to XT60 adaptors so I didnt have to change all my batteries and esc's at once. Quote Link to comment Share on other sites More sharing options...
Reno Racer Posted March 12, 2012 Share Posted March 12, 2012 I just wish that Lipo manufacters (or someone else) would standardise connectors, even if its just done by 2 or 3 size/capacity standards. Looking through my Lipos I have , JST, EC3, XT60, Deans, 3.5mm bullet, 4mm bullet. 5mm bullet. I did standardise to Deans, then to XT60, although on larger high capacity lipos/set ups I try and use 4mm bullet connectors. I've now got more DIY adaptors for ESCs/chargers/Lipos than I have Lipos!! Quote Link to comment Share on other sites More sharing options...
Redex Posted March 19, 2012 Share Posted March 19, 2012 Changed over to XT60's now. I like the way the heat shrink goes right inside the connector base for added security. With a small footprint and 60A capability thats fine, my E-Pioneer only draws 41A max. Quote Link to comment Share on other sites More sharing options...
Vecchio Austriaco Posted March 19, 2012 Share Posted March 19, 2012 Christian, go abroad and try to connect your travel iron - Italy, France, Germany, Australia and so on - all plugs and sockets are different. And those are used in millions. So why should there be harmonisation on a connection system used by a much smaller number of users? Also a connection system, as for instance the Multiplex one, can help building up market barrieres. Not everybody can change connectors so if you cannot you are stuck to the material sold by a particular brand. By the way hope the XT60s are good as I purchased 10 recently... Cheers VA Quote Link to comment Share on other sites More sharing options...
buster prop Posted March 19, 2012 Share Posted March 19, 2012 I use them as well. The connector body is made from a hard plastic that won't melt when you solder wires to the gold pins. XT60's can carry far more current than my planes need, they stay together and aren't too hard to pull apart. I did once have a Deans plug/socket that went intermittent so replaced it with XT60 and also 4mm connectors on my bigger planes. I. My smaller planes still use 3 mm gold bullet connectors. Quote Link to comment Share on other sites More sharing options...
Vecchio Austriaco Posted March 26, 2012 Share Posted March 26, 2012 Stuff arrived from the big fish last week - of course I was not at home so I had to drive to the parcel office. I am quite disappointed - those connectors are harder to open than my deans! It doesn't say anything at the connector - just ST60 - so I am not sure if these are the original ones or just a copy. I actually bought them as I have one pair - which came with a Turnigy charger - which worked really smooth. Anybody else with these problems? Any solutions? Cheers VA Edited By Vecchio Austriaco on 26/03/2012 12:11:47 Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted March 26, 2012 Share Posted March 26, 2012 I have noticed this too Vecchio....it seems not all XT60's are created equal.....there appear to be some "copies" around...the versions I got from HK attached to my LiPos are a very bright & definite yellow colour...the ones I got from GC are darker yellow & are certainly harder to mate...both to each other & between types..... I think the Deans connectors had the same issue....the copies were not as good as the originals... Quote Link to comment Share on other sites More sharing options...
Trevor Crook Posted March 26, 2012 Share Posted March 26, 2012 Yes, I've read that there are some poor copies that melt when you solder them. I've also read some bad feedback on some that GC has sold. Hence, despite being a regular GC customer I buy my XT60s from E-Bay. I always choose a top rated UK seller, and verify that the seller states that they are originals, using high temperature nylon. Usually buy them with the correct heatshrink, too. No issues so far. Quote Link to comment Share on other sites More sharing options...
Vecchio Austriaco Posted March 28, 2012 Share Posted March 28, 2012 News: the connectors have all a problem of a small burr in the hole of the female part. Some fine abrasive paper like 800 and the problem is solved. Now they do what they should do. cheers VA- happy camper department Quote Link to comment Share on other sites More sharing options...
