Tim Mackey Posted November 19, 2010 Share Posted November 19, 2010 Several years on, and we still seem to get quite few people having problems with binding their Spektrum radio gear, so with a view to bumping up an old idea we had some years back, ( Video Tutorials ) I have done a short and simple video of the procedure to assist those who may be struggling. I've used one of the clone "orange" receivers, purely because I had a load of them to test and bind up before passing them on to people, so it was "to hand" - but the procedure is exactly the same.I'm not saying that there are no faulty items - BUT, in my experience, almost every single case of reported "faults" is down to operator error, so take a quick look here before you parcel it all up and return it You'll need 1) A fully charged 4 or 5 cell battery pack, ( I find this more reliable for binding than using a speed controllers BEC ).2) A bind plug3) Your transmitter - with a model assigned and selected in memory4) A servo.5) The receiver ( with satellite(s) if applicable) The method I prefer to to use is the bind plug inserted directly into the Rx, rather than using the special 3 wire harness and socket /switch unit. If you do use such a harness, then remember it MUST be a special 3 wire harness, and MUST be plugged into the batt/bind socket on the Rx. A "normal" switch /charge harness will NOT work.Heres a picture first of the bits you will need. Once successfully bound, it should not be necessary to bind the rx to the tx again - its a once-only operation, performed whilst setting the model up at home before the maiden flight. Fail-safe settings ( where available on the receiver ) should also be implemented during this bind procedure. In my extensive experience a receiver will NOT simply lose bind without user intervention - a bind plug MUST be inserted in to the correct socket before a receiver can enter bind mode.Even accidentally pushing the bind button on the DX7 rear casing will not "unbind" a properly bound receiver unless a bind plug is inserted. In this scenario, you are using the bind button to enter "range check" mode, and it goes without saying that this should NOT be done whilst the model is airborne! Video below. I have also done a similar one to explain about "brown outs" and difference between this and binding etc. This is over HERE Edited By Tim Mackey - Administrator on 19/11/2010 14:31:58 Quote Link to comment Share on other sites More sharing options...
Terry Walters Posted November 19, 2010 Share Posted November 19, 2010 Thanks Timbo - much appreciated by someone who looks at the Spektrum instructions every time and still can't make much sense of the wiring shown - yours is much clearer. Terry Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted November 19, 2010 Share Posted November 19, 2010 Just for clarification, for those who might not be fully aware of the regulations embodied in CAP 658 - you said "fail safe settings can also be implemented (where applicable)". For the avoidance of all doubt if the system is fitted with a failsafe, then that system must have the failsafe correctly set, with a minimum of the throttle set to idle. That is the case whatever the weight of the model. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted November 19, 2010 Author Share Posted November 19, 2010 Fairy snuff leccyflyer - although I was really referring to the fact that only certain receivers have a "proper" failsafe function - many simply affect only the throttle channel.I have ( hopefully ) clarified this a bit better in the post now.Edited By Tim Mackey - Administrator on 19/11/2010 14:10:49 Quote Link to comment Share on other sites More sharing options...
Ross Clarkson Posted November 25, 2010 Share Posted November 25, 2010 Just a quick question regarding this. Do the servos NEED to be connected to the Rx during the binding process, or is it quite alright just to connect them up after binding? Quote Link to comment Share on other sites More sharing options...
Pete B Posted November 25, 2010 Share Posted November 25, 2010 No, Ross, it just means you can confirm it's all go instantly. Pete Quote Link to comment Share on other sites More sharing options...
Ross Clarkson Posted November 25, 2010 Share Posted November 25, 2010 Cool. I was just wondering as i have just binded/bound (??) my Yak 54 without the servos connected, then connected the servos and they seem to be fine so was just checking. Cheers Pete. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted November 25, 2010 Author Share Posted November 25, 2010 I have a small update on binding. A friend recently asked me to check his MO as he was experiencing a problem - he reckoned that after successfully binding, the RX would then re-enter bind mode ( rapid flashing ) when he connected power, even though he had removed the bind plug I discovered that he was using a BEC mode ESC to power up and bind, which is fine, until he did the following.Bind completed, he removed the bind plug, switched everything off, and then inserted the BEC power plug into the batt/bind socket of the rx. Switching everything back on, the bind light started to flash, although everything worked fine. The problem is that the BEC plug has 3 wires + - and signal. The signal wire was effectively causing a short across the two outer pins of the receiver socket - exactly what a bind plug does - so the receiver thought a bind plug had been inserted!Plugging the BEC into any other socket restored order, and solved the issue.Of course, in normal use, the BEC lead will plug into throttle channeso no problem will exist. Just thought it worth mentioning, as I bet he is not the only one to have done this. Quote Link to comment Share on other sites More sharing options...
Terry Walters Posted November 25, 2010 Share Posted November 25, 2010 Been there done that more than once (slow learner) - at least I know what causes it now!! Thanks Timbo very useful. Terry Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted November 25, 2010 Author Share Posted November 25, 2010 Great - at least one more frustrated modeller calmed down and happy Quote Link to comment Share on other sites More sharing options...
Ross Clarkson Posted November 26, 2010 Share Posted November 26, 2010 I forgot to say, cheers for this great thread Timbo. To be honest, it couldn't get any easier after this advice. I did it yesterday and the process was so simple, I didn't even need the servos connected! Good tip about 3 lead switches too, because I wouldn't have done it this way without reading this thread. Literally, battery connected, bind plug in and your procedure followed = instant success. Top stuff, thanks. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted November 26, 2010 Author Share Posted November 26, 2010 Crikey, two satisfied customers Quote Link to comment Share on other sites More sharing options...
Phil Claridge Posted November 26, 2010 Share Posted November 26, 2010 sticky buns in the mail poss tim? Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted November 26, 2010 Author Share Posted November 26, 2010 Nah, but maybe some "flatbread" Quote Link to comment Share on other sites More sharing options...
Phil 9 Posted February 8, 2011 Share Posted February 8, 2011 thanks Timbo i had forgotten this and thought my tx was broken it was just me Quote Link to comment Share on other sites More sharing options...
Gary Binnie Posted February 9, 2011 Share Posted February 9, 2011 Some of the Spektrum receiver instructions mention a second binding ' so that the true low throttle and neutral control surface positions are set'. I can't see the need to do this apart from the initial failsafe positions might be wrong due to servo reverse selections on the transmitter (you won't know if the servo directions are correct until the system has been bound). Any thoughts folks? Cheers Gary Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted February 9, 2011 Author Share Posted February 9, 2011 I think you have it gary - it is best to do a bind after all the radio is installed and working, in case you have altered things and the original failsafe are no longer appropriate. Quote Link to comment Share on other sites More sharing options...
Gary Binnie Posted February 9, 2011 Share Posted February 9, 2011 I brought it up because I'm rebinding an AR7000 in an RES glider to a new transmitter and I couldn't find the bind port! I resorted to reading the instructions which told me the bind port is sideways under the main channels, doh! I saw the warning on rebinding while I was there. I only seem to be able to set the throttle channel to a failsafe position (I'm using it for spoilers). I've tried holding the elevator and aileron (controlling the rudder!) stick in a preset position while pressing the Tx bind button (a one armed paper hanger job!) but I'm just getting throttle channel movement (SmartSafe I think). I tried pre-setting the controls with trim input but that didn't work either. This is with a JR DSX9, the 35 meg instructions that you get with the 2.4 version (bananas!) mention a pre-set controls fail safe mode in SPCM that has to be programmed in the Tx. The 2.4 supplement seems to say that if you insert the bind plug in a JR RD921, power it up then remove it (the Rx light will still flash) then set the transmitter controls to where you want them, then press the bind button (phew!) it should work. I'm going to try this with the AR7000 and see what happens. I'm after a descending spiral as a fail safe setting. Will report back!! Quote Link to comment Share on other sites More sharing options...
Gary Binnie Posted February 9, 2011 Share Posted February 9, 2011 Works perfectly!! Bargain!! Just need to see if this method works with the AR500. You learn something every day!! Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted February 9, 2011 Author Share Posted February 9, 2011 ONLY throttle has proper failsafe on this receiver ( and in fact most spekky receivers )The manual is very misleading, suggesting that you set the presets on all channels whilst binding....it wont do anything. All that happens on signal loss is they hold "last known good".The will NOT move to any preset position. Quote Link to comment Share on other sites More sharing options...
Gary Binnie Posted February 9, 2011 Share Posted February 9, 2011 It is misleading and it doesn't mention this facility of pre-setting the other controls at all. The RD921 manual notes two types of fail safe, SmartSafe and Preset Failsafe but doesn't appear to explain how you achieve the second version unless I missed it (I got that from the transmitter supplement!). Interesting that they recommend this for sailplanes, exactly what I was trying to do. Another thought, if you did the second binding the normal way as Spektrum suggest you would lose your fail safe settings!! Quote Link to comment Share on other sites More sharing options...
Gary Binnie Posted February 9, 2011 Share Posted February 9, 2011 This has been discussed before at the Spektrum failsafes thread. A list of Spektrum receivers with pre-set fail safe was given by Horizon, does not include the AR7000 which appears to support it!? All good fun!! Quote Link to comment Share on other sites More sharing options...
Gary Binnie Posted February 9, 2011 Share Posted February 9, 2011 Sorry to hog this thread but I did some digging, from other forums it seems that there are two firmware states for the AR7000, one that supports pre-set failsafe and one that does not. I wanted to check as I don't like doing things with receivers that they are not supposed to officially do!! Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted April 1, 2011 Author Share Posted April 1, 2011 bump Quote Link to comment Share on other sites More sharing options...
Shaunie Posted October 5, 2011 Share Posted October 5, 2011 Just a little bit to add to the info:- Just set up an AR7000 into an Seagull Edge 540. I performed a bind on the receiver and then set up the mixes for the additional elevator and aileron servos (on Aux1 and Aux2). Whenever the receiver was powered up the servos for the mixed channels would kick to odd positions and when the signal was picked up from the transmitter they would then adopt a normal position. After a re-bind they behaved normally. It seems to me that when a bind is performed that the mix setting is stored in the receiver. I didn't make a specific note of the behaviour so this is from memory but it should be easy enough to reproduce if anybody wishes too! Shaun. Quote Link to comment Share on other sites More sharing options...
