Simon Chaddock Posted December 5, 2010 Share Posted December 5, 2010 The retract cycle in any full size plane takes quite a few seconds. For a model a scale retract speed will be a bit quicker but a dedicated retract servo like the HS-75BB only takes less than a second for full travel. You could use a proportional servo and a speed reducer but why not gear down a low power servo so that it has a travel time of say a couple of seconds? A micro 3.9g servo generates 0.7 kgcm torque and a travel time of 0.2 sec/60 degrees.What if you geared its motor down a further 20:1?14 kgcm of torque (twice that of HS-75BB), a 2 second travel time and only a 250mA full load current draw.Of course with gears and bearings to handle the torque it would end up a bit bigger & heavier but not that much. An interesting thought. Quote Link to comment Share on other sites More sharing options...
Former Member Posted December 5, 2010 Share Posted December 5, 2010 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted December 5, 2010 Author Share Posted December 5, 2010 Eric Agreed but the HS-75BB I quoted is a specific retract servo and as it has a "bang-bang" non proportional action it cannot be slowed down with a plug in gizmo. Really my observation was if you are going to design a specific retract servo why not make it slower acting. It will be lighter and perhaps more important draw less current for any given torque. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted December 5, 2010 Share Posted December 5, 2010 The new type of electrical all in one screw jack retracts are quite slow, I can see these catching on now they are being supplied in reasonable numbers. Quote Link to comment Share on other sites More sharing options...
Brian Parker Posted December 5, 2010 Share Posted December 5, 2010 Small Stepper motor? Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted December 5, 2010 Share Posted December 5, 2010 I use standard servos but fairly meaty (this pair below are supposed to be around 6kg each). In that way you can slow them down via the transmitter (if yours will do it) otherwise a servo slow as Eric says. I don't know about anyone else but I don't think I could modify a retract servo in the way that Simon suggests, though it is of course feasible. The other benefit of using a std servo is you can adjust the end stops fairly easily. I do like the look of the electric units however. Cheers Danny Quote Link to comment Share on other sites More sharing options...
