Russ P Posted December 7, 2010 Share Posted December 7, 2010 Building my first electric model and the ESC has a brake function, can anyone explain what this and does. Quote Link to comment Share on other sites More sharing options...
Steve W-O Posted December 7, 2010 Share Posted December 7, 2010 It's for electric cars, to slow them down. All it does is load the motor when it is acting as a generator, so acts as a brake Quote Link to comment Share on other sites More sharing options...
David perry 1 Posted December 7, 2010 Share Posted December 7, 2010 Not quite Steve. The brake stops the motor spinning against a driving force. So, it COULD be useful in a car but it is VERY useful if you are flying an electric glider, because then you need to stop the prop spinning so that it folds. If you are building a sports model with no folding prop it will simply stop the prop when you bring the throttle to idle. David Quote Link to comment Share on other sites More sharing options...
sparks59 Posted December 7, 2010 Share Posted December 7, 2010 Glider pilots may use this feature also I believe to slow prop rotation prior to folding. David beat me to it!Edited By sparks59 on 07/12/2010 11:35:14 Quote Link to comment Share on other sites More sharing options...
Russ P Posted December 7, 2010 Author Share Posted December 7, 2010 Thanks for the info. Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted December 7, 2010 Share Posted December 7, 2010 Russ Stopping the prop (so it folds) can really reduce drag and extend the glide so, as already said here, it's an ESC feature that glider pilots will nearly always switch to 'on'. It's surprising how much of a brake effect a spinning prop will have. Fixed wing tractor prop models tend to have the brake 'off' so the prop continues to spin when the throttle stick is back and where the brake effect can be useful and help slow the model down, especially when landing. Also a dead prop can look a bit silly to be honest, especially if it's a scale model. Quote Link to comment Share on other sites More sharing options...
Erfolg Posted December 7, 2010 Share Posted December 7, 2010 Although the primary function of the brake has been identified. In my experience there is at least one other use. If your field is rough, or your model has no UC (both true in my case) , then a folding prop can be very useful. Although not a scale modeller to any degree, I have one model where a folding prop is very useful. The model is a Do335, where even a good landing would have the motor coming adrift from the fuselage mounting. Since fitting a folder on the front motor, this to date has not been an issue. I also fly a sports model, where a folder is fitted. In this case I was breaking a propeller on most landings, a folder solved the problem. There has been quite a lot of discussion in the past regarding folding, freewheeling non folders and braked non folders. I do not think the arguments matter much in the landing phase, it is about practicality. Quote Link to comment Share on other sites More sharing options...
Russ P Posted December 7, 2010 Author Share Posted December 7, 2010 Erfolg - my model doesn't have u/c so a belly landing is the only option and will stress the prop, so I'll have a look at the folding prop solution. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted December 7, 2010 Share Posted December 7, 2010 But there is no need to use the brake facilityin those circumstances - the prop will fold perfectly well without a brake upon any contact with the ground. Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted December 7, 2010 Share Posted December 7, 2010 Posted by Russ Payne on 07/12/2010 13:12:53:Erfolg - my model doesn't have u/c so a belly landing is the only option and will stress the prop, so I'll have a look at the folding prop solution. What's the model Russ? Quote Link to comment Share on other sites More sharing options...
Erfolg Posted December 7, 2010 Share Posted December 7, 2010 I am not sure if the brake is activated on my scale and sports models. I am not sure if really matters in that case, as I use power on all phases of the flight. So I guess to some extent, I have gone of topic a little, although I think there is a relationship. I would now argue for a glider the brake facility matters, but is best used with a folding prop. If not, you are into the argument does a freewheeling electric motor contribute more drag, than a braked non-folding prop. What is certain the folder wins by a country mile, when folded, that is braked. Quote Link to comment Share on other sites More sharing options...
