Phil May Posted March 27, 2011 Share Posted March 27, 2011 I have just bought a Phoenix 2.5 flight sim off e-bay which came with the square Futaba adapter. This was advertised as in perfect working order, I have a problem with the square plug into the radio which keeps needing a wiggle to keep the sim working - is this a common fault fault with them and what is the best way around it Cheers Phil Quote Link to comment Share on other sites More sharing options...
David Gilder Posted March 27, 2011 Share Posted March 27, 2011 Phil If you know someone else with same controller, try the plug on that tx and if problem is the same it is most likely the lead that has a problem. If thats the case you have 2 options. 1. open a complaint through ebay that item is broken, or 2. purchase a new lead from Phoenix! Hope that helps and good luck! Dave Quote Link to comment Share on other sites More sharing options...
Steve W-O Posted March 27, 2011 Share Posted March 27, 2011 If you have no luck, cheapest solution is to buy one of t h e s e the adaptors work fine on Phoenix, then you have a spare USB interface for Real Flight or FMS. They are worth keeping a spare, and I use a 5m stereo extension on Phoenix to protect the dongle. Quote Link to comment Share on other sites More sharing options...
birdy Posted March 27, 2011 Share Posted March 27, 2011 I thought that you had to have a genuine adaptor for it to work - otherwise everyone would buy one of those and then just buy the DVD (which you can get of the phoenix website for £9.95). Quote Link to comment Share on other sites More sharing options...
John Privett Posted March 27, 2011 Share Posted March 27, 2011 I assume that Steve just means to use the Futaba adapter lead from that ebay kit - and ignore the USB plug unless you want it for FMS as well. However, the "JR" jackplug on my Phoenix dongle is a 3.5mm stereo plug. The one pictured on ebay looks like it's a mono jack and is described as 2.5mm. I do sometimes need to gently wiggle the plug on my Futaba FF7 when using Phoenix to get it to work. Can't understand why Futaba switched from the old DIN plug/sockets - these little plastic plug/sockets don't seem overly reliable... Quote Link to comment Share on other sites More sharing options...
birdy Posted March 27, 2011 Share Posted March 27, 2011 The sockets seem fine when used for buddy leads, but mine doesn't like the sim lead - so I use my JP planet system instead for phoenix. Phil have you checked all the pins are ok - my first lead had a pushed-in pin. Quote Link to comment Share on other sites More sharing options...
r6dan Posted March 27, 2011 Share Posted March 27, 2011 When I used my futaba 6ex with phoenix it was always playing up because the square jack is just mounted straight in the circuit board not mounted in the body of the tx, if you know what i mean Quote Link to comment Share on other sites More sharing options...
Pat (rActive) Harbord Posted March 27, 2011 Share Posted March 27, 2011 I have had problems with the dongle. I disassembled the connector and found two wires hanging by a thread. I snapped a reference photo with my mobile phone and cut off the wires and re soldered after cutting around an inch off the cable to make sure the wires were in good nick. No problems since then Quote Link to comment Share on other sites More sharing options...
Phil May Posted March 27, 2011 Author Share Posted March 27, 2011 Thanks guys, I'm going to borrow a new adapter lead tomorrow and give it a go. Being fair to the guy I bought it from, he said if no luck he will refund my cash, could not ask for more than that Phil Quote Link to comment Share on other sites More sharing options...
Steve W-O Posted March 28, 2011 Share Posted March 28, 2011 Posted by John Privett on 27/03/2011 20:47:05: I assume that Steve just means to use the Futaba adapter lead from that ebay kit - and ignore the USB plug unless you want it for FMS as well. However, the "JR" jackplug on my Phoenix dongle is a 3.5mm stereo plug. The one pictured on ebay looks like it's a mono jack and is described as 2.5mm. I do sometimes need to gently wiggle the plug on my Futaba FF7 when using Phoenix to get it to work. Can't understand why Futaba switched from the old DIN plug/sockets - these little plastic plug/sockets don't seem overly reliable... I didn't read the whole of the ad, but the ones I have bought have been 3.5mm, and have worked fine, obviously 2.5 would not work. I did say I used a 5m stereo extension, which is 3.5mm though I did not state it. Very good of the seller to be so decent about it. Quote Link to comment Share on other sites More sharing options...
Phil May Posted March 28, 2011 Author Share Posted March 28, 2011 I just tried another lead and it was fine, so I just opened up the plug and hey presto one of the wires hanging off. A little soldering job for me a bit later. Phil Quote Link to comment Share on other sites More sharing options...
