Tony Smith 7 Posted March 30, 2011 Share Posted March 30, 2011 Hi, Can anyone tell me if silver paint (most probably Plasticote) on a model will interfere with 2.4GHz reception? The receiver has two "whisker" aerials, and I plan to run one along the underside of the fuselage (which will not be painted silver), but the other one will be fitted vertically inside. Thanks, Tony S Quote Link to comment Share on other sites More sharing options...
Steve W-O Posted March 30, 2011 Share Posted March 30, 2011 Some silver paint uses aluminium, and if so it could affect the signal Quote Link to comment Share on other sites More sharing options...
Paul Newell 2 Posted March 30, 2011 Share Posted March 30, 2011 I spray paint using Halfords car paints both aerosol and mixed at the counter varieties. Have always avoided mettallic paints but pearlescent ones usually have a mica fill to produce the effect. This does not cause me any problems with Spektrum receivers, aerials inside fuselages, in eSoaring models. With this type of model we fly at long distances and sometimes very high. Quote Link to comment Share on other sites More sharing options...
Pete B Posted March 30, 2011 Share Posted March 30, 2011 You'll probably find that, in practice, it won't be a problem, Tony. There are a couple of threads here and here, where Orange Rx's have been shielded by various means, coping with biccy tins, lead and brick very well, so a bit of silver paint is unlikely to affect them! I think the real problem is likely to be carbon, as witnessed by the carbon fus-specific Rx's. Pete Edited By Pete B on 30/03/2011 11:21:48 Quote Link to comment Share on other sites More sharing options...
Tony Smith 7 Posted March 31, 2011 Author Share Posted March 31, 2011 Thanks guys. I think I might have to do some tests. I was hoping that someone would say they have silver painted models with no problems. Quote Link to comment Share on other sites More sharing options...
flytilbroke Posted March 31, 2011 Share Posted March 31, 2011 The same or nearly the same question has been asked quite a few times, I say that as the answers given were also the same... Some flyers have had a problem, from perhaps one orientation to a much more consistant problem at any angle. Which has caused model loss. My take on the variety of answers is why chance it? Use a receiver designed for metalic or carbon fuselages. Quote Link to comment Share on other sites More sharing options...
r6dan Posted March 31, 2011 Share Posted March 31, 2011 Since the carbon question came up, and today is wayyyy to windy to fly I have been experimenting... my Acro wot fus has been lined with carbon, I run the coax outside the fus normally, at 90` to each other (tis a futaba 2.4 rx) so i put the aerial inside the carbon and range tested it, no problem, then I tied the aerials together in a knot, again range checked fine, both were power down at a min of 75 meters, I will do the same with the frsky rx as well... Quote Link to comment Share on other sites More sharing options...
Tony Smith 7 Posted April 1, 2011 Author Share Posted April 1, 2011 Posted by flytilbroke on 31/03/2011 15:22:49: My take on the variety of answers is why chance it? Use a receiver designed for metalic or carbon fuselages. I'm not sure I can get such a thing for my radio, but I am also a bit puzzled about what it means if a receiver is supposed to be compatible with carbon fuselage. I mean if the carbon fibre blocks the signal then nothing the receiver can do will help. A quick read of the manual for the AR6255 "6-channel receiver optimized for carbon fiber fuselage installations" seems to just be telling you to have extend the aerials outside the fuselage. That suggests that the optimisation is really just the provision of long enough wires before the active part of the aerials to allow them to reach the outside. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted April 1, 2011 Share Posted April 1, 2011 Exactly right Tony. Quote Link to comment Share on other sites More sharing options...
Tony Smith 7 Posted April 1, 2011 Author Share Posted April 1, 2011 Posted by Tim Mackey - Administrator on 01/04/2011 13:57:41:Exactly right Tony. Thanks. Glad I wasn't missing anything. My "normal" receiver has the aerials long enough to do that if it proves necessary. Quote Link to comment Share on other sites More sharing options...
