Hamish Posted April 6, 2011 Share Posted April 6, 2011 Considered purchasing a Pretty, more for its appearance, however looking at posting on this forum it did not compare well, performance wise, with the Blizzard. I now ask how the Blizzard compares with the Radian Pro? Quote Link to comment Share on other sites More sharing options...
PatMc Posted April 6, 2011 Share Posted April 6, 2011 They are totally different.The Blizzard is fast(ish) & aerobatic the Radian is a slow floater.Do you want aerobatic performance or glide duration ? Quote Link to comment Share on other sites More sharing options...
Hamish Posted April 6, 2011 Author Share Posted April 6, 2011 Thanks Pat. I have a Radian and it is how you say. It has the same appearance as the Blizzard and I wondered if the motor in the Blizzard resulted in the increased performance but it would appear there is more to it. I am looking for a bit more aerobatic but preferred the looks of the Pretty(horrible name) to the foam of the Radian and Blizzard. Any suggestions? Quote Link to comment Share on other sites More sharing options...
PatMc Posted April 6, 2011 Share Posted April 6, 2011 Hamish are you sure you're thinking of the Blizzard not the EasyGlider ? The Blizzard has a V tail, is smaller & not really like the Radian at all. Yep, the Pretty isn't a good name. Ken Anderson has started wearing lipstick & painting his nails since he mistook a reference to "Ken's Pretty" for a compliment. Quote Link to comment Share on other sites More sharing options...
Hamish Posted April 6, 2011 Author Share Posted April 6, 2011 You are correct Pat, I have not been comparing properly although I was influenced by them both being foam. I probably am looking for a model with the same flight characteristics of the Blizzard but no foam. Quote Link to comment Share on other sites More sharing options...
Tom Wright 2 Posted April 6, 2011 Share Posted April 6, 2011 Hi Hamish. If you leave the stickers off the Pretty and think of of new name ,the pretty is a very capable all rounder, TW2. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted April 6, 2011 Share Posted April 6, 2011 ST Blaze. Quote Link to comment Share on other sites More sharing options...
simon burch Posted April 13, 2011 Share Posted April 13, 2011 I've had a JP Pretty for the past 2 years and had hours of fun with it. The real weak point is the supplied motor and prop. Just had my fourth prop fail, which again has taken the motor with it. Rather than replace with original gear, I fitted a Emax BL2215/25 motor and a cheap folding prop with a metal spinner from Robot Birds. Tried it yesterday in the blustery conditions, and it was perfect. The lower KV on the motor combined with the slightly larger prop (9x6) has made the whole thing much smoother, plus the quality of the Emax motor looks for superior to the supplied bell motor.Its a bit of tight fit to get the motor into the nose making sure the motor wires don't rub against the casing, but I'm really pleased with mine. Pulling around 160W and 14-15 amps according to my watt meter. Might try with a set of 10x6 blades as I'm sure I'm still well within the specs of the Emax motor.Thought it was worth mentioning as the standard motor seems to be out of stock everywhere, plut the standard folding prop is not fit for purpose. I think I've had over 4 blades shear since I've owned mine. If you are not a fan of flying lumps of foam, the I think the Pretty is a good option, just don't put too much faith in the standard supplied electronics. Cheers,Simon Quote Link to comment Share on other sites More sharing options...
Hamish Posted April 13, 2011 Author Share Posted April 13, 2011 Thanks Simon. Hopefully tomorrow will be collecting Pretty from LMS. Will pay attention to motor and I have others available if I need to change. Quote Link to comment Share on other sites More sharing options...
simon burch Posted April 13, 2011 Share Posted April 13, 2011 I think this time, the motor was damaged by the prop being thrown, but on previous motors, it was the grub screw on the mounting plate coming loose which did the damage (motor wobbled around and ate all the wires). Looking at the replacement motors at BRC Hobbies, they look different to the little 1300kv bell motors which mine have had in, so maybe they have updated the kits. I would definitely junk the supplied folding prop and treat youself to a Graupner unit or one of the metal spinners from Robotbirds. Blades here , spinner here .The supplied blades on my Pretty were very thin at the root and very roughly finished (chewed wouldn't be far off the mark !!). There is very little material around the pivot point and everytime they have failed is when I've been launching. Bit unerving as the prop is quite close at this point. I tacked my motor wires to the side of the fuselage, then ran some 5 minute epoxy over them to make sure they can no flap about. There is very little room around the motor in the nose, you will see what I mean when you put yours together, so make 100% sure nothing can move. It's quite sleek model, so I put some contrasting colour under one wing tip to help orientation at distance. Not a floater in comparison to some, but handles the wind really well (was gusting 25mph yesterday when I was flying mine). If there are thermals about your normally in for some fun. Cheers, Simon Quote Link to comment Share on other sites More sharing options...
Hamish Posted April 13, 2011 Author Share Posted April 13, 2011 In my other models I take the motors out now and again to give the bearings a good oil, so epoxy to the wiring would not be an option. I use a gaffer type tape to hold the wires in place and can normally get it way up to the front of the motor keeping the wires clear. Have used a number of props from GC, HK and at one time treated model to expensive unit, which although well made, did not justify the cost. I have an eHawk and hope that the Pretty will be as nimble and able to do manoeuvres I can't do with the eHawk, although that may well be down to my lack of experience and ability. Roll on weekend and weather permitting I should maiden. Quote Link to comment Share on other sites More sharing options...
PatMc Posted April 13, 2011 Share Posted April 13, 2011 Dunno if it's possible on the Pretty but I have seen a models with a hole drilled in the nose to allow the motor wires out & another hole a little further back for them to re-enter the fuselage. The wires were then faired with a piece of plastic from a suitable moulded bubble packaging - small Easter egg container springs to mind. Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted April 13, 2011 Share Posted April 13, 2011 hamish--i own a pretty and also a blizzard.......they are like chalk and cheese...you mention your ability...i would prob say try the pretty and then (later) get a blizzard.....as the pretty will/is a bit more forgiving...... ken anderson ne..1. Quote Link to comment Share on other sites More sharing options...
Hamish Posted April 13, 2011 Author Share Posted April 13, 2011 Thanks for the info Ken. I may give the Blizzard a try later on. What has put me off the Blizzard is I have assumed it is made of the same material as the Radian and It very quickly looses its appearance as the slightest twig leaves an indentation and as the wing brackets broke I used tape to hold them in place which again removes the surface finish. I am pleased with how the Radian performs and now doubt the Blizzard will be the same, but I like a model to have a good appearance. Quote Link to comment Share on other sites More sharing options...
simon burch Posted April 13, 2011 Share Posted April 13, 2011 Yep, gaffer tape would do the job just as well. I find the expoy will easily ping off if I needed to remove anything, but as the motor is only 9 quid, I'm not too worried about long term maintenance (I can see the front an rear bearing if I was to oil it). I've seen a few Blizzards, but never actually seen someone using them as a glider just blasting around as like a hotliner. Look to have amazing performance, I just don't like foam models. Cheers, Simon Quote Link to comment Share on other sites More sharing options...
Hamish Posted April 14, 2011 Author Share Posted April 14, 2011 Pick up Pretty from LMS today. Nice looking model but found the folowing Covering has bubbles which I have taken out with iron.There is a seam where the two halves of the Fuz have been joined. Will paint to blend in.Motor wires are hot glued to Fuz so should not chaff with motor. Fitted plug to ESC and ran motor up. 20Amps on Wattmeter and the ESC has 12A marked on it???? Should not take to long to fit out, but no doubt I will get diverted elsewhere. Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted April 15, 2011 Share Posted April 15, 2011 Posted by PatMc on 06/04/2011 11:39:30: Hamish are you sure you're thinking of the Blizzard not the EasyGlider ? The Blizzard has a V tail, is smaller & not really like the Radian at all. Yep, the Pretty isn't a good name. Ken Anderson has started wearing lipstick & painting his nails since he mistook a reference to "Ken's Pretty" for a compliment. naughty young pat---you'll be well advised not to stand too near the cliff face next time out gliding...in case you 'slip' over........ ken anderson ne....1. Quote Link to comment Share on other sites More sharing options...
Hamish Posted April 15, 2011 Author Share Posted April 15, 2011 Gosh Ken, you have got me worried. I can assure you I have not yet started to wearing lipstick and painting my nails. If I get the "Hamish's Pretty" I will be providing a pair of specs. Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted April 15, 2011 Share Posted April 15, 2011 hamish--have no fear--you sound like a fine upright character...made of good stuff...the same as me....where we lead other's will follow and all that.........you need 'broad shoulder's'with some of the so called flying friends i know here..... ... ken anderson ne...1.(the leader)...not. Quote Link to comment Share on other sites More sharing options...
