Paul Williams Posted October 15, 2011 Share Posted October 15, 2011 I have noticed after some time the yellow tygon fuel pipe goes stiff. I am using it as a clunk pipe in the tank. This prevents the clunk from weighting the pipe to the bottom of the tank. NOT GOOD. Is there a more flexible option that would be petrol resistant? Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted October 15, 2011 Share Posted October 15, 2011 paul-any silicone fuel tubing should do the job....for you... LMS is the place to go-- if you get stuck...PM me i'll put some in the post for you.... ken anderson ne..1.. plumbing dept. Quote Link to comment Share on other sites More sharing options...
Wingman Posted October 15, 2011 Share Posted October 15, 2011 Presume because its tygon that you are using petrol in which case silicon is no good as it swells up. You could try neoprene. Quote Link to comment Share on other sites More sharing options...
Paul Williams Posted October 16, 2011 Author Share Posted October 16, 2011 Posted by Wingman on 15/10/2011 13:18:42: Presume because its tygon that you are using petrol in which case silicon is no good as it swells up. You could try neoprene. sounds good any idea where I can find such stuff wingman Quote Link to comment Share on other sites More sharing options...
Wingman Posted October 16, 2011 Share Posted October 16, 2011 Paul, look here - note also soft tygon also maybe a heavier clunk? Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted October 17, 2011 Share Posted October 17, 2011 Yes, I too, have heard that not all Tygon is created equal with some being softer & longer lasting than others...... Might be worth trying a different "brand".... Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted October 17, 2011 Share Posted October 17, 2011 An alternative is Nitrile tubing used for petrol and oil applications its als ok for model diesel fuel . Its black and come in all sizes . It will eventually harden but with a proper heavy petrol filter clunk it should last a couple of seasons . I believe falcon aviation sell it but it can be found on the internet quite easily. Quote Link to comment Share on other sites More sharing options...
