fly boy3 Posted January 15, 2012 Share Posted January 15, 2012 Hi all I am currently connecting up a Corona RP4s1 Syn reciever.When connected ,I was informed to teach the ESC with regards to the throttle. I cannot find this info on the thread, wonder if someone could enlighten me again. CheersEdited By fly boy3 on 15/01/2012 11:48:04 Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted January 15, 2012 Share Posted January 15, 2012 Turn everything off (disconnect). Remove prop - (as me how I know that ) - Set throttle to fully open. Turn on Tx, reconnect everything at aeroplane. Lots of bleeps - when they stop move throttle to min. More bleeps. Turn everything off, disconnect. With throttle on min, turn all back on a gain and reconnect. You're throttle should now work normally. If more sophisticated programming beyond just setting the throttle is needed - e.g. setting brakes and timing etc. - you really need the instruction sheet. BEB Quote Link to comment Share on other sites More sharing options...
fly boy3 Posted January 15, 2012 Author Share Posted January 15, 2012 Cheers BeB, thats the info I required. Will have to save it somwhere safe for the future. LoL. Cheers Quote Link to comment Share on other sites More sharing options...
fly boy3 Posted January 15, 2012 Author Share Posted January 15, 2012 Hi Bebb, taught ESc as above post. Full control of motor from min. to max. Only thing motor does not start until thottle is near mid point. Have I taught it badly, ? or is it acceptable. CheersEdited By fly boy3 on 15/01/2012 12:53:38 Quote Link to comment Share on other sites More sharing options...
PatMc Posted January 15, 2012 Share Posted January 15, 2012 Here's a scan from the Hobbywing/Turnigy instructions If you want a copy of the full instruction sheet PM me your email & I'll send you a pdf of it (about 3.8MB) Quote Link to comment Share on other sites More sharing options...
fly boy3 Posted January 15, 2012 Author Share Posted January 15, 2012 Thanks Pat, tried it again, but motor does not move until near mid throttle stick positon, then all is fine ? Cheers Quote Link to comment Share on other sites More sharing options...
John Tee Posted January 15, 2012 Share Posted January 15, 2012 Hi Try doing as above but with the throttle trim in low position as well. John Quote Link to comment Share on other sites More sharing options...
fly boy3 Posted January 15, 2012 Author Share Posted January 15, 2012 Cheers lads, sorted at third time of trying. Another prob. now ,every thing working correctly, but no beeps when battery is connected. Can I call this a problem or a "whoopsy". Should have stuck with IC. LoLEdited By fly boy3 on 15/01/2012 16:55:31 Quote Link to comment Share on other sites More sharing options...
PatMc Posted January 15, 2012 Share Posted January 15, 2012 Might be a daft question but is the motor still connected to the ESC when there's no beeps ? Quote Link to comment Share on other sites More sharing options...
fly boy3 Posted January 15, 2012 Author Share Posted January 15, 2012 Yes Pat, as I say all is working correctly. Not tried a prop on it yet. Cheers Quote Link to comment Share on other sites More sharing options...
fly boy3 Posted January 15, 2012 Author Share Posted January 15, 2012 Hi Pat ,knew I should have read a bit more before putting a daft post on this thread. With motor connected all is well, beeps and all.Thanks all for the help, must say again, a great forum. CheersEdited By fly boy3 on 15/01/2012 18:46:19 Quote Link to comment Share on other sites More sharing options...
